Date/Time: Wed, 08 May 2024 16:04:21 +0000
How to display replay clock time while replaying historical data
View Count: 947
[2018-01-09 14:50:59] |
DevTrader79 - Posts: 44 |
I have set up real time clock which displays when I am live in market. However I like to see replay clock time while replaying historical data. Let's say I am replaying historical data Nov 23rd 2017 8:30am. Do we have any study which should display the historical replay time in hr:mm:ss. Thanks |
[2018-01-10 07:56:21] |
Update to the current version of Sierra Chart following these instructions here: Software Download: Fast Update Use this particular study: Clock - RealTime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-10 15:33:38] |
Didn't work. Any idea ? Screenshot included |
ReplayTimeProblem.jpg / V - Attached On 2018-01-10 15:32:11 UTC - Size: 490.8 KB - 297 views Attachment Deleted. |
[2018-01-10 19:16:51] |
We do not see a problem with this. The Clock-RealTime study matches exactly the current time being replayed. What is the exact name of the clock study that you added to the chart?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-10 19:18:11
[2018-01-11 14:14:00] |
Clock-RealTime
RealTimeClock.jpg / V - Attached On 2018-01-11 14:12:54 UTC - Size: 119.56 KB - 299 views |
[2018-01-11 17:54:14] |
This is not making any sense. As long as you are on the current version of Sierra Chart, tell us the version, then the Clock-Realtime study will during a replay indicate the last time of the last bar in the chart. This is totally reliable. This has been verified. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-11 18:31:03] |
There is another thought about this which can be the source of the problem. Make sure you are on the latest release: Software Download: Fast Update And go to Tools >> Manage Chart Drawings Window. Remove any text drawings which seem to be related to the real-time clock. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
