Date/Time: Sat, 27 Apr 2024 05:24:45 +0000
Not connecting....
View Count: 629
[2018-01-09 11:24:44] |
spfcbrasil - Posts: 6 |
I´ve subscribed sierra chart to get DAX data.... today sierra chart is not connecting... can you help me ?
[2018-01-09 11:38:11] |
the problem should be with data feed login details....but I havent received none and I dont know what I should do now.
[2018-01-09 12:30:56] |
There are no login details required. Make sure that Global Settings >> Data/Trade Service Settings >> Service is set to "SC Data-All Services". The DAX futures symbol is DYH18. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
