Date/Time: Fri, 03 May 2024 05:55:21 +0000
How to get market type for a symbol?
View Count: 546
[2018-01-08 22:23:22] |
LenderDevTest - Posts: 15 |
Hello, how can I check is the symbol belongs to forex market?
[2018-01-08 23:08:47] |
The easiest way is to look at the category for it in File >> Find Symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-08 23:08:55
[2018-01-09 00:23:31] |
sorry, I meant in the programming way
I do not find any function for that in ACSIL Interface Members.
Date Time Of Last Edit: 2018-01-09 00:31:58
[2018-01-09 01:39:10] |
No there is no way to programmatically determine this. That is an impossibility. It would never be practical with all of the various support for external data and trading services.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-09 01:39:27
