Date/Time: Sat, 04 May 2024 18:55:17 +0000
Stop Loss not Triggering?
View Count: 841
[2018-01-08 15:35:05] |
User742056 - Posts: 5 |
Hey guys, For some reason, when I enter a [SIM] trade and disable chart trading (Ctrl + Shift + C) my stop does not trigger sometimes when prices move through it. I disable chart trading so I'm able to move/draw on the chart freely without risk of moving my orders. Is this a bug or do you recommend a setting change. It really isn't that big of a deal, just a bit annoying. Thanks. |
[2018-01-08 20:02:59] |
This does make sense and is explained here: http://www.sierrachart.com/index.php?page=doc/TradeSimulation.php#FillPricesWrong_OrdersDoNotFill Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
