Date/Time: Mon, 06 May 2024 13:40:06 +0000
range TPO tool
View Count: 1215
[2018-01-08 12:40:40] |
User336964 - Posts: 29 |
Hi support, Is there any tool for drawing range TPO like "Draw volume profile" tool? Right now, it is attainable by using TPO profile chart in Studies, changing "profile time period length" and merging profiles but it is time consuming. So is it possible to quickly draw a range TPO in any other way? |
[2018-01-08 20:11:46] |
This is not supported in the way that you are thinking. You can accomplish something like this by using this particular TPO Profile Chart study Input: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#Input_NumberOfTPOProfilePeriods You will want to set it to: From Start Date-Time To End Date-Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-08 20:13:46
