Date/Time: Thu, 02 May 2024 05:44:29 +0000
Volume by price study help with rolling days
View Count: 2540
[2018-01-07 06:29:22] |
User995923 - Posts: 64 |
Hello Is there any setting to create a 2 day rolling volume profile? Not rolling based on candles but actual days. E.g. today I want to view only yesterdays volume combined with todays developing volume. Tomorrow I want to view only todays volume combined with tomorrows developing volume. The closer setting I found is the Volume Graph period Type: One period at End of Fixed Time Length. However the problem with this setting is that as the day is developing, it removes old volume from the start of the previous day. Regards |
[2018-01-07 21:17:06] |
You need to use this particular Volume Graph Period Type: Volume By Price Study: One Period from Most Recent Period Start to End Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-08 18:36:18] |
Tried it with time period length for fixed time: 2 days but still it is drawing only the current day's volume profile. Is there any additional setting that I should tweak? Regards |
[2018-01-08 19:20:41] |
gomifromparis - Posts: 244 |
Maybe because we're Monday, and there was no volume yesterday ? Just wanted to add that if you are having issues, you can also have a look at the GomMPPro (commercial study, see https://www.gomicators.com/market-profile/ ), that will give you a rolling profiles using the setting "LastNDays" , with N=2. However it counts session days, not week days, so it will add the Friday volume to the Monday profile. I'm attaching a pic. Disclaimer : I 'm the author. |
gommprolling.png / V - Attached On 2018-01-08 19:19:57 UTC - Size: 67.83 KB - 400 views |
[2018-01-08 19:36:35] |
Tried it with time period length for fixed time: 2 days but still it is drawing only the current day's volume profile. We will look this over.
[2018-01-10 22:13:51] |
Update to the latest version of Sierra Chart: Software Download: Fast Update Use this particular Volume Graph Period Type: Volume By Price Study: One Period at End of Fixed Time Length - Auto-Skip Empty Days Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-11 03:55:49] |
It's working perfectly thank you very much! Regards |
