Date/Time: Sat, 21 Nov 2026 05:01:07 +0000
range?
View Count: 1419
| [2018-01-06 15:47:50] |
| User378082 - Posts: 33 |
When I point to a bar, where to show the range? I can not find it.
| [2018-01-08 02:17:51] |
For this you will need to use the Bar Difference study: Bar Difference And then you will need to use the Chart Values tool: http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-01-12 20:08:23] |
| User327694 - Posts: 25 |
It would very helpful to have an actual Range study. Bar Difference of High - Low <> Range ... Range = (High - Low) + 1 tick Thanks |
| [2018-01-12 20:22:59] |
This can be done. In addition to the links above, refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-13 10:09:36
| [2018-01-12 22:48:50] |
OK. IMHO this is a glaring omission though. |
| [2018-01-13 10:12:00] |
You can modify the provided Bar Difference study to meet your requirements: How to Build an Advanced Custom Study from Source Code: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
