Date/Time: Sun, 05 May 2024 00:08:24 +0000
New s_BarPeriod and custom bars
View Count: 966
[2018-01-06 12:22:01] |
DabbaDo - Posts: 146 |
I like this new structure. If it had a string like CustomChartName and if there was an IntradayBarPeriodTypeEnum like IBPT_CUSTOM, then it would be possible for me to know which of my custom bar types is running in a chart. This seems much better than the NinjaTrader custom bar problem, where custom bar writers are forced to cast the NT BarsPeriodType enum to an int that might be used by other custom bars. FWIW, Cheers, Dale |
[2018-01-08 02:15:14] |
This will be supported in the next release.
