Date/Time: Mon, 29 Apr 2024 16:25:17 +0000
Bollinger Squeeze 2
View Count: 1368
[2018-01-05 19:05:44] |
User312841 - Posts: 25 |
I would like to color background on the red dots which have a value of -0.0. The green dots have a value of 0.0. Attached shows the -0.0 value, and the failed attempt. TIA |
BBS2 Red Dot.JPG / V - Attached On 2018-01-05 18:46:51 UTC - Size: 42.2 KB - 359 views BBS2 Fail.JPG / V - Attached On 2018-01-05 18:53:00 UTC - Size: 124.28 KB - 342 views |
[2018-01-05 19:18:02] |
You need to change the comparison to =ID8.SG2<0 Do not use =.
[2018-01-05 19:30:53] |
I did try that previously, and that did not work either.
BBS2 Less Than Fail.JPG / V - Attached On 2018-01-05 19:29:46 UTC - Size: 126.37 KB - 309 views |
[2018-01-05 20:12:15] |
Do not use -0 but just 0.
[2018-01-05 20:37:55] |
Nope again. I tried going the other way too with no luck. =ID8.SG2 > 0 Would it make sense to change the code to something like: 0.001 for green, -0.001 for red Thanks |
BBS2 Less Than - no minus - Fail.JPG / V - Attached On 2018-01-05 20:33:15 UTC - Size: 160.04 KB - 366 views |
[2018-01-08 06:02:03] |
Enable the option Use Full Precision when Evaluating Alert Formula. We will make the value for the dots .001. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
