Date/Time: Thu, 12 Nov 2026 18:19:08 +0000
Missing Charts
View Count: 1114
| [2018-01-05 18:41:11] |
| User136641 - Posts: 3 |
All tech studies are gone from my charts. Went to help/download current version: Did not solve problem. Went to Sierra Charts to download current version: Deleted old, installed current version: got error message. Still no studies. SierraChartStudies.dll is present in my program folder.
| [2018-01-05 22:54:27] |
For some reason this post had gotten overlooked. There are numerous postings about this in the last couple of days. This problem is caused by your antivirus software deleting the SierraChartStudies.dll file. You need to disable your antivirus/security software. For more information, refer to: Software Download: Antivirus/Anti-malware Software Flagging Sierra Chart Installer or other Files as Unsafe/Infected Once you do that, then update Sierra Chart with Help >> Download Prerelease to get the missing file. Instructions: Software Download: Fast Update SierraChartStudies.dll is present in my program folder. Disregard this because you probably are looking in the wrong folder. The problem is what we say and trust us on that.
