Date/Time: Mon, 29 Apr 2024 18:40:38 +0000
line on close
View Count: 894
[2018-01-05 01:21:37] |
User472677 - Posts: 316 |
in sc, default color for line on close is green. I have added the study 'add additional symbol' I want the lines for two symbols of different colors. no matter what I do, they are always the same color.
Date Time Of Last Edit: 2018-01-05 01:25:59
[2018-01-06 00:13:34] |
Refer to: Color Settings for Graph Draw Types Also you must must must use the latest prerelease when using Add Additional Symbol. We see you are not. Do not use it in an earlier version because it is not properly implemented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
