Date/Time: Tue, 22 Sep 2026 19:10:44 +0000
Heiken Ashi reversal alert
View Count: 2742
| [2018-01-04 22:47:54] |
| User976133 - Posts: 38 |
Looking to create an alert for when the Heiken Aski bars change from red to green, or from green to red. Any ideas on where to begin? My attempts so far have been unsuccessful.
| [2018-01-07 09:37:10] |
This depends upon the method of color coding of the bars. In general you need to look at the Open (O) and Close (C) values for the current bar and the prior bar and use these values in the alert condition formula. Refer to this section here for the identifiers: Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables You can see these values using the Chart Values Tool: Chart Drawing Tools: Chart Values/Crosshair Are you using the Heikin-Ashi study as the main price graph in the chart? The information above is based on that being true. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-07 09:38:09
