Date/Time: Fri, 03 May 2024 17:14:26 +0000
Label Box
View Count: 1228
[2018-01-04 18:02:17] |
User509820 - Posts: 69 |
Is there a way to have a label box like the clock study. That can display text of "up trend" or "down trend" based on studies? Thanks
[2018-01-04 19:40:43] |
Yes, but you will have to create this using the Advanced Custom Study Interface and Language: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-27 04:19:03] |
This is very difficult is there anyway to have this done already? Thanks
