Date/Time: Fri, 24 May 2024 06:57:19 +0000
Bitfinex datafeed
View Count: 927
[2018-01-04 17:16:44] |
User107382 - Posts: 5 |
Hi, Do you have a plan to have Ripple (XRP) cryptocurrency datafeed support ? is´s having more financial volume than bitcoin ... thank you |
[2018-01-04 19:36:32] |
Yes this is coming soon.
[2018-01-17 04:10:08] |
Hi, I noticed that SC has an option to Bitfinex's trading. How do I setup my Bitfinex to trade using SC : thanks, Carlos |
[2018-01-17 13:35:44] |
Bitfinex trading is not currently supported. That particular service is to a server from a third-party which is not available. Bitfinex trading will come. We cannot give a time estimate.
[2018-01-17 20:56:35] |
Hi, Are you sure :: I am asking because I went to Data/Trade Service Settings and I saw a service called "Bitfinex Trading", please see the attached file. thanks |
Private File |
