Date/Time: Thu, 09 May 2024 01:31:40 +0000
Universal Renko in Bar period types
View Count: 1089
[2018-01-04 15:41:10] |
Glenn Infinity - Posts: 103 |
With the newest version of the charting "Universal Renko" has been removed from "bar Period Type in chart settings > main settings. Is there a way to recreate it or get it back with an older version?
[2018-01-04 18:07:18] |
It has been renamed and slightly changed (Flex Renko Inverse Setting Bars). Refer to: https://www.sierrachart.com/index.php?page=doc/RenkoCharts.html#UniversalRenkoBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-04 18:07:41
