Date/Time: Mon, 06 May 2024 00:08:13 +0000
questions
View Count: 850
[2018-01-04 14:03:14] |
User518622 - Posts: 2 |
Hi Can you tell me the difference between Sierra Chart Zip Installer and the simple Download ? why there is no linux version? Regards |
[2018-01-04 18:43:00] |
If you do not know the difference, then do not use the zip installer. There is no direct support for Linux. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-04 18:53:20] |
I'm not sure It is an intelligent answer
[2018-01-05 19:10:41] |
It is the appropriate answer in this case. If you have to ask the question, then do not use the zip installer. It is that simple. Based upon the question, we are going to evaluate your capabilities, and give you an answer which is appropriate for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-05 19:11:04
