Date/Time: Thu, 12 Nov 2026 18:19:11 +0000
Symbol is unknown, real time data are not allowed
View Count: 1776
| [2018-01-04 11:18:09] |
| User721970 - Posts: 5 |
Hello, I am trying to show live data for NQ through Ninjatrader Brokerage. (SQG webAPI) Still see error: Symbol is unknown, real time data are not allowed. Can you help me please? |
| [2018-01-04 18:40:22] |
Refer to this section here about this: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-01-04 19:20:07] |
Thank you, that is set properly. I am connected but see only historical data. I bought 1st Real-Time Data Connection. I think that is mandatory for CME.? I can see: Is Approved for CME nonprofessional Trading accounts exchange fees: Yes. Is it necessary to buy CME with Market Depth for nonprofessional Trading accounts even if I have data from continuum already? Thank you, P. |
| [2018-01-04 20:09:00] |
OK we see. We did not notice you had the Sierra Chart Exchange Data Feed active. In this particular case, you do need to activate this exchange: Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts 3.25 USD/month You can do this here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures You can get the data through CQG if you want but since you already have the data feed active you might as well use it for this month and then can cancel it at the end of the month. After this you can rely on CQG for market data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-04 20:09:58
| [2018-01-04 20:33:08] |
Thank you, if I want to use numbers bars and market profile I suppose I will need CME with Market Depth for nonprofessional Trading accounts Market Depth Included: Yes for 5.25 USD / month, right? Is it possible have live intraday CQG data without active Sierra Chart Exchange Data Feed? |
| [2018-01-04 20:34:34] |
Neither of those studies require market depth data. So the answer is no. Is it possible have live intraday CQG data without active Sierra Chart Exchange Data Feed? CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges And have your broker help you with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-04 20:35:05
| [2018-01-04 20:44:01] |
I still dont understand. My broker told me that through CQG FIX Trading is not possible have market data: Hello Petr, Are you asking about CQG Fix Trading? We do not support that data connection. The Continuum connection you have currently is CQG Data, but it's just a different API. Not all APIs are compatible with all platforms. |
| [2018-01-04 20:45:41] |
When using CQG FIX Trading, for market data Sierra Chart will use the CQG Web API(also apparently called continuum) in the background for this. Here are the complete details about this: CQG Trading Platform Service: CQG Account Requirements Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-04 20:46:13
