Date/Time: Tue, 22 Sep 2026 19:10:43 +0000
Transparent color bar
View Count: 1526
| [2018-01-03 15:44:29] |
| sellis67 - Posts: 105 |
can't seem to figure out how to make my background color bar based on study more transparent. Can you point me in the right direction? thx.
| [2018-01-03 17:58:17] |
We are not really sure what you are referring to in regards to the particular study being used and the Draw Style. For the available Draw Styles, refer to: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
