Date/Time: Sun, 28 Apr 2024 21:00:45 +0000
[Locked] - bid ask depth bars ?
View Count: 1589
[2018-01-03 13:13:17] |
zippyzip - Posts: 293 |
shouldn't these match quantity of the dom exact ? there always off by +-50 , some times there spot on also
Private File |
[2018-01-03 18:01:31] |
Here is the documentation for the study: Bid & Ask Depth Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-11 01:55:12
[2018-01-11 01:55:52] |
Since these are snapshots only when there is a change at the best Bid and Ask levels, when the Mode Input is using a setting which directly correlates to the current market depth data, then for the very last value of the Bid and Ask Depth Bars study, there is going to be some inconsistency at times to the total Bid depth and total Ask depth that you currently see and other market depth displays in Sierra_Chart, since when there are quantity changes at levels other than at the best Bid or Ask, there will be inconsistencies momentarily. This thread is locked and there is no further comment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-11 10:33:47
