Date/Time: Sun, 28 Apr 2024 22:29:05 +0000
ACSIL - X & Y Constant Relationship
View Count: 686
[2018-01-03 11:41:04] |
User553714 - Posts: 184 |
Hi, I don't think there are currently sc variables to set the X & Y Constant Relationship with ACSIL and the two associated variables (Bars & Values Range)? If this is the case can you please consider adding the variables? Chart Scale and Scale Adjusting: X & Y Constant Relationship Scaling The constant X & Y relationship is important to ensure calculating consistent angles between zooming in/out and it would be helpful to be able to set this through ACSIL instead of trying to remember to set them manually. Thanks |
[2018-01-17 10:52:15] |
Hi, Will you be able to add these, I thought they would be relatively simple to add? Regards
