Date/Time: Sat, 27 Apr 2024 14:21:42 +0000
Bid & Ask Depth Bars indicator
View Count: 1369
[2018-01-03 00:59:48] |
User626121 - Posts: 82 |
Hello! Could you please enable more than 50 depth levels to use for the Bid & Ask Depth Bars indicator? I get about 150-200 depth levels per Bid and Ask side from my data feed. But when I put in a value greater than 50 in the "maximum depth levels to use (historical market depth)", it jumps back to 50. Thank you |
[2018-01-03 02:55:09] |
Yes this will come. But allow about 60 days or so for it.
[2018-07-19 21:04:28] |
User117347 - Posts: 46 |
How to increase the Market depth on bid ask depth bars?
[2018-07-27 18:58:41] |
Not sure we understand the question. Is that study set to use the Historical Market Depth data?
