Date/Time: Fri, 03 May 2024 22:29:06 +0000
Initial Balance High & Low set in %
View Count: 1489
[2018-01-02 17:29:10] |
s291117 - Posts: 28 |
Hello SUpport, is it possible to set the Initial Balance High & Low according to a value set in % from the 1st hour values ? IB High & IB Low 200% would draw specific lines on the chart. Besides, I do not succeed to make them appear on Volume & TPO Profil chart. Is this normal ? Thanks for precisions. |
[2018-01-02 19:18:37] |
This can be done through the Extension Multiplier # Inputs with the Initial Balance study: Initial Balance: Inputs Besides, I do not succeed to make them appear on Volume & TPO Profil chart. Is this normal ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
