Date/Time: Wed, 01 May 2024 18:33:19 +0000
Position Quantity (J5,J8) always zero in spreadsheet
View Count: 814
[2018-01-02 09:55:48] |
User841591 - Posts: 42 |
I want to trade HSI option e.g. MHI-OPT-201801-30800-C-HKFE-10-HKD with spreadsheet through the trade provider IB . I find the cells J5 and J8 always output 0 even though the order has filled. Pls note it is normal for the HSI futures.
[2018-01-02 17:49:44] |
For this symbol use the Order Fill Calculated Trade Position as documented here: Trading Information Windows: Using Order Fill Calculated Trade Positions Enable this for the chart only and not globally. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-02 17:50:14
