Date/Time: Mon, 29 Apr 2024 02:59:33 +0000
SC + Rithmic -> accessing an old futures contract
View Count: 1138
[2017-12-30 11:18:51] |
Cavalry3162 - Posts: 523 |
Hello SC, i am using SC with the Rithmic datafeed and want to open a specific futures contract.. this is no big deal for those >= 2010, e.g. ESH8-CME what translates to ES March 2018 but i dont know how to open a contract pre 2010 like March 2008 for example. ESH08-CME doesnt seem to work. Any advise? thanks, Andreas |
[2017-12-30 22:48:05] |
You cannot do this. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Single Digit Year Limitation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-02 14:03:19] |
Hello SC, that doesnt seem to work... i've tried ESH8 and ESH08 - while ESH8 at least tried to load data and then threw an error, ESH18 didnt do a thing... see log: ESH8 1 Min #1 | Reloading chart. | 2018-01-02 14:00:59
ESH8 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_DTC_Test\Data\ESH8.scid | 2018-01-02 14:00:59 SC Data - All Services | Starting real-time market data updates for: ESH8. ID: 3 | 2018-01-02 14:00:59 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESH8 | 2018-01-02 14:00:59 SC Data - All Services | Requesting security definition data for: ESH8. ID: 3 | 2018-01-02 14:00:59 Intraday data recording state for symbol ESH8 is set to download 'Pending'. | 2018-01-02 14:00:59 Delaying start of download for ESH8 | 2018-01-02 14:00:59 HD Request # 4 | Downloading Intraday chart data for ESH8 to the file ESH8.scid. Service: scdataallservices | 2018-01-02 14:01:04 HD Request # 4 | Download start date-time: 2017-06-30 14:01:04.000 | 2018-01-02 14:01:04 HD Request # 4 | Error downloading historical Intraday data for ESH8. The futures symbol format is invalid. The year must be 2 digits. | 2018-01-02 14:01:04 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH8 | 2018-01-02 14:01:04 HD Request # 4 | Completion time: 0s | 2018-01-02 14:01:04 HD Request # 4 | Intraday data download complete for ESH8. Unique request ID: 3 | 2018-01-02 14:01:04 Removed historical data download ID 3 | 2018-01-02 14:01:04 Real-time Intraday chart data file updates started for ESH8 | 2018-01-02 14:01:04 Opened cached Intraday file: C:\SierraChart_DTC_Test\Data\ESH8.scid | 2018-01-02 14:01:04 Intraday chart data file opened for ESH8 | 2018-01-02 14:01:04 ESH08 1 Min #1 | Reloading chart. | 2018-01-02 14:01:16 ESH08 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_DTC_Test\Data\ESH08.scid | 2018-01-02 14:01:16 |
[2018-01-02 18:27:48] |
Only use the symbols you find in File >> Find Symbol. do not manually enter them unless they are stock symbols. There is not data available for ESH08 with the Sierra Chart Historical Data Service. For ESH18, follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is No Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-02 18:43:12] |
very funny, SC.. i specifically asked for ESH08 data and you suggested to use the SC historical data service... so, is there no way to load up a ESH08 contract? fun fact: i have the data locally available and cant access it... |
[2018-01-02 19:08:32] |
Yes, because we did not check to see if that contract was available. The answer and the documentation was in relation to the fact that you needed to use a service which supports two digit years. So no, the Intraday data for that symbol is apparently not available back that far. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-02 19:24:26] |
how far back goes the history you offer? file -> find symbol obviously wont help me with that as it goes as "far" back as sep 2017 which obviously would be a bad joke if you wouldnt have further back data available.. |
[2018-01-03 08:55:13] |
It varies based on symbol and is documented here generally: Sierra Chart Exchange Data Feed: What is Included When you are near the edge of the beginning of the historical data for a particular futures market you just have to use trial and error to see what data is available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-03 08:55:50
