Date/Time: Sun, 28 Apr 2024 14:27:48 +0000
Trouble connectin to crypto data feed
View Count: 936
[2017-12-29 01:24:27] |
User558377 - Posts: 31 |
Reading Internal Order ID file. | 2017-12-25 19:03:59 Reading Trade Orders file. | 2017-12-25 19:03:59 Reading Trade Positions file. | 2017-12-25 19:03:59 Listening on UDP port 22904. | 2017-12-25 19:03:59 Software version: 1674 | 2017-12-25 19:03:59 Usage end date: 2018-01-25 | 2017-12-25 19:03:59 Enabled for: Advanced Features. | 2017-12-25 19:03:59 Enabled for: Advanced Features 2. | 2017-12-25 19:03:59 Enabled for: Sierra Chart Historical Data Service. | 2017-12-25 19:03:59 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-12-25 19:03:59 Current selected Data/Trading service: SC Data - All Services | 2017-12-25 19:03:59 Chart Update Interval: 500 | 2017-12-25 19:03:59 Time Zone: +00:00:00 (UTC+00) | 2017-12-25 19:03:59 2017-12-25 11:04:52 Local computer time | 2017-12-25 19:03:59 2017-12-25 19:04:52 Local computer time in UTC | 2017-12-25 19:03:59 2017-12-25 19:04:52 Local computer time in SC Time Zone | 2017-12-25 19:03:59 2017-12-25 19:17:07 Server time in UTC | 2017-12-25 19:03:59 Local computer UTC time and Server UTC time difference: 736 seconds. | 2017-12-25 19:03:59 Notice: Your computer's clock is off by 736 seconds. For help with this, press the 'Send for Analysis' button. | 2017-12-25 19:03:59 Program path: C:\SierraChart\ | 2017-12-25 19:03:59 Data Files path: C:\SierraChart\Data\ | 2017-12-25 19:03:59 OS Version Number: 6.1 | 2017-12-25 19:03:59 Locale Setting: C | 2017-12-25 19:03:59 Checking for new symbol settings for service code scdataallservices | 2017-12-25 19:03:59 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-12-25 19:03:59 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-12-25 19:03:59 Received 5 login tokens. | 2017-12-25 19:04:53 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-12-25 19:04:54 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-12-25 19:04:54 Requesting symbol settings for service code scdataallservices. Overwrite = on. | 2017-12-25 19:04:56 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-12-25 19:04:58 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-12-25 19:04:58 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-12-25 19:04:58 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-12-25 19:04:58 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-12-25 19:04:58 Symbol settings received. | 2017-12-25 19:04:59 Processed 5606 symbol settings. | 2017-12-25 19:04:59 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-12-25 19:05:00 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-12-25 19:05:00 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-12-25 19:05:00 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-12-25 19:05:00 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-12-25 19:05:00 SC Data - All Services | Connected to data server. | 2017-12-25 19:05:03 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-12-25 19:05:04 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-12-25 19:05:04 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-12-25 19:05:04 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-12-25 19:05:04 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-12-25 19:05:04 SC Data - All Services | Disconnected. | 2017-12-25 19:05:35 SC Data - All Services | Disconnected. | 2017-12-25 19:05:35 Checking for new symbol settings for service code BitfinexCryptocurrency.exchange | 2017-12-25 19:05:35 Current selected Data/Trading service: Bitfinex | 2017-12-25 19:05:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:05:35 HTTPS connection to www.sierrachart.com:443 (6) | Creating socket. Using TLS 1.2. | 2017-12-25 19:05:35 HTTPS connection to www.sierrachart.com:443 (6) | Connecting to IP: 204.15.192.108. | 2017-12-25 19:05:35 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:05:38 DTC Client socket (7) | Creating socket. Using TLS 1.2. | 2017-12-25 19:05:40 DTC Client socket (7) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:05:40 HTTPS connection to www.sierrachart.com:443 (6) | Socket gracefully closed by remote side. | 2017-12-25 19:05:42 HTTPS connection to www.sierrachart.com:443 (6) | Received socket Close event. | 2017-12-25 19:05:42 HTTPS connection to www.sierrachart.com:443 (6) | Initiating close of socket by core. | 2017-12-25 19:05:42 Symbol settings are up-to-date for BitfinexCryptocurrency.exchange | 2017-12-25 19:05:42 HTTPS connection to www.sierrachart.com:443 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-12-25 19:05:42 HTTPS connection to www.sierrachart.com:443 (6) | Closed. | 2017-12-25 19:05:42 DTC Client socket (7) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:06:01 * DTC Client socket (7) | Initiating close of socket by core. | 2017-12-25 19:06:01 DTC Client socket (7) | Closed. | 2017-12-25 19:06:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:06:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:06:01 Bitfinex | Disconnected. | 2017-12-25 19:06:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:06:01 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:06:04 DTC Client socket (9) | Creating socket. Using TLS 1.2. | 2017-12-25 19:06:04 DTC Client socket (9) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:06:04 DTC Client socket (9) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:06:25 * DTC Client socket (9) | Initiating close of socket by core. | 2017-12-25 19:06:25 DTC Client socket (9) | Closed. | 2017-12-25 19:06:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:06:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:06:25 Bitfinex | Disconnected. | 2017-12-25 19:06:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:06:25 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:18:45 DTC Client socket (10) | Creating socket. Using TLS 1.2. | 2017-12-25 19:18:45 DTC Client socket (10) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:18:45 DTC Client socket (10) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:19:05 * DTC Client socket (10) | Initiating close of socket by core. | 2017-12-25 19:19:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:19:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:19:05 DTC Client socket (10) | Closed. | 2017-12-25 19:19:05 Bitfinex | Disconnected. | 2017-12-25 19:19:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:19:05 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:19:08 DTC Client socket (12) | Creating socket. Using TLS 1.2. | 2017-12-25 19:19:08 DTC Client socket (12) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:19:08 DTC Client socket (12) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:19:30 * DTC Client socket (12) | Initiating close of socket by core. | 2017-12-25 19:19:30 DTC Client socket (12) | Closed. | 2017-12-25 19:19:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:19:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:19:30 Bitfinex | Disconnected. | 2017-12-25 19:19:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:19:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:19:33 DTC Client socket (13) | Creating socket. Using TLS 1.2. | 2017-12-25 19:19:33 DTC Client socket (13) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:19:33 DTC Client socket (13) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:19:54 * DTC Client socket (13) | Initiating close of socket by core. | 2017-12-25 19:19:54 DTC Client socket (13) | Closed. | 2017-12-25 19:19:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:19:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:19:54 Bitfinex | Disconnected. | 2017-12-25 19:19:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:19:54 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:19:57 DTC Client socket (14) | Creating socket. Using TLS 1.2. | 2017-12-25 19:19:57 DTC Client socket (14) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:19:57 USD 1 Min #1 | Reloading chart. | 2017-12-25 19:20:10 USD 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\USD.scid | 2017-12-25 19:20:10 Intraday data recording state for symbol USD is set to download 'Pending'. | 2017-12-25 19:20:11 HD Request # 2 | Downloading Intraday chart data for USD to the file USD.scid. Service: BitfinexTradingDTC | 2017-12-25 19:20:11 Compressing file: C:\SierraChart\Data\USD.scid. This may take a while. | 2017-12-25 19:20:11 HD Request # 2 | Download start date-time: 2017-06-22 19:20:11.000 | 2017-12-25 19:20:11 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2017-12-25 19:20:11 Socket (16) | Creating socket. | 2017-12-25 19:20:11 Socket (16) | Connecting to IP: 192.81.56.146. | 2017-12-25 19:20:11 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-12-25 19:20:11 HD Request # 2 | Sending historical data logon request message. | 2017-12-25 19:20:11 Socket (16) | Initiating close of socket by core. | 2017-12-25 19:20:12 HD Request # 2 | Error downloading historical Intraday data for USD. Historical data logon error: Data files folder not set for service code: BitfinexTradingDTC | 2017-12-25 19:20:12 Socket (16) | Shutdown started. Waiting for graceful close. | 2017-12-25 19:20:12 Historical data download thread signaled to stop. | 2017-12-25 19:20:12 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USD | 2017-12-25 19:20:12 HD Request # 2 | Completion time: 0s | 2017-12-25 19:20:12 HD Request # 2 | Intraday data download complete for USD. Unique request ID: 1 | 2017-12-25 19:20:12 Removed historical data download ID 1 | 2017-12-25 19:20:12 Socket (16) | Socket gracefully closed by remote side. | 2017-12-25 19:20:12 Socket (16) | Closed. | 2017-12-25 19:20:12 DTC Client socket (14) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:20:17 * DTC Client socket (14) | Initiating close of socket by core. | 2017-12-25 19:20:17 DTC Client socket (14) | Closed. | 2017-12-25 19:20:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:20:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:20:17 Bitfinex | Disconnected. | 2017-12-25 19:20:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:20:17 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:20:20 DTC Client socket (17) | Creating socket. Using TLS 1.2. | 2017-12-25 19:20:20 DTC Client socket (17) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:20:20 DTC Client socket (17) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:20:42 * DTC Client socket (17) | Initiating close of socket by core. | 2017-12-25 19:20:42 DTC Client socket (17) | Closed. | 2017-12-25 19:20:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:20:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:20:42 Bitfinex | Disconnected. | 2017-12-25 19:20:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:20:42 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:20:45 DTC Client socket (18) | Creating socket. Using TLS 1.2. | 2017-12-25 19:20:45 DTC Client socket (18) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:20:45 DTC Client socket (18) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:21:06 * DTC Client socket (18) | Initiating close of socket by core. | 2017-12-25 19:21:06 DTC Client socket (18) | Closed. | 2017-12-25 19:21:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:21:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:21:06 Bitfinex | Disconnected. | 2017-12-25 19:21:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:21:06 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:21:09 DTC Client socket (20) | Creating socket. Using TLS 1.2. | 2017-12-25 19:21:09 DTC Client socket (20) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:21:09 DTC Client socket (20) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:21:30 * DTC Client socket (20) | Initiating close of socket by core. | 2017-12-25 19:21:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:21:30 DTC Client socket (20) | Closed. | 2017-12-25 19:21:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:21:30 Bitfinex | Disconnected. | 2017-12-25 19:21:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:21:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:21:33 DTC Client socket (21) | Creating socket. Using TLS 1.2. | 2017-12-25 19:21:33 DTC Client socket (21) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:21:33 DTC Client socket (21) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:21:54 * DTC Client socket (21) | Initiating close of socket by core. | 2017-12-25 19:21:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:21:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:21:54 DTC Client socket (21) | Closed. | 2017-12-25 19:21:54 Bitfinex | Disconnected. | 2017-12-25 19:21:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:21:54 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:21:57 DTC Client socket (22) | Creating socket. Using TLS 1.2. | 2017-12-25 19:21:57 DTC Client socket (22) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:21:57 DTC Client socket (22) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:22:18 * DTC Client socket (22) | Initiating close of socket by core. | 2017-12-25 19:22:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:22:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:22:18 DTC Client socket (22) | Closed. | 2017-12-25 19:22:18 Bitfinex | Disconnected. | 2017-12-25 19:22:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:22:18 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:22:21 DTC Client socket (24) | Creating socket. Using TLS 1.2. | 2017-12-25 19:22:21 DTC Client socket (24) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:22:21 DTC Client socket (24) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:22:42 * DTC Client socket (24) | Initiating close of socket by core. | 2017-12-25 19:22:42 DTC Client socket (24) | Closed. | 2017-12-25 19:22:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:22:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:22:42 Bitfinex | Disconnected. | 2017-12-25 19:22:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:22:42 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:22:45 DTC Client socket (25) | Creating socket. Using TLS 1.2. | 2017-12-25 19:22:45 DTC Client socket (25) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:22:45 DTC Client socket (25) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:23:06 * DTC Client socket (25) | Initiating close of socket by core. | 2017-12-25 19:23:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:23:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:23:06 DTC Client socket (25) | Closed. | 2017-12-25 19:23:06 Bitfinex | Disconnected. | 2017-12-25 19:23:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:23:06 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:23:09 DTC Client socket (27) | Creating socket. Using TLS 1.2. | 2017-12-25 19:23:09 DTC Client socket (27) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:23:09 Sierra Chart account data changed. Requesting updated account information. | 2017-12-25 19:23:11 Successfully processed Sierra Chart account data. | 2017-12-25 19:23:13 HTTPS connection to www.sierrachart.com:443 (29) | Creating socket. Using TLS 1.2. | 2017-12-25 19:23:13 HTTPS connection to www.sierrachart.com:443 (29) | Connecting to IP: 204.15.192.108. | 2017-12-25 19:23:13 HTTPS connection to www.sierrachart.com:443 (29) | Socket gracefully closed by remote side. | 2017-12-25 19:23:20 HTTPS connection to www.sierrachart.com:443 (29) | Received socket Close event. | 2017-12-25 19:23:20 HTTPS connection to www.sierrachart.com:443 (29) | Initiating close of socket by core. | 2017-12-25 19:23:20 HTTPS connection to www.sierrachart.com:443 (29) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-12-25 19:23:20 HTTPS connection to www.sierrachart.com:443 (29) | Closed. | 2017-12-25 19:23:20 DTC Client socket (27) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:23:30 * DTC Client socket (27) | Initiating close of socket by core. | 2017-12-25 19:23:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:23:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:23:30 DTC Client socket (27) | Closed. | 2017-12-25 19:23:30 Bitfinex | Disconnected. | 2017-12-25 19:23:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:23:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:23:33 DTC Client socket (30) | Creating socket. Using TLS 1.2. | 2017-12-25 19:23:33 DTC Client socket (30) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:23:33 DTC Client socket (30) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:23:54 * DTC Client socket (30) | Initiating close of socket by core. | 2017-12-25 19:23:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:23:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:23:54 DTC Client socket (30) | Closed. | 2017-12-25 19:23:54 Bitfinex | Disconnected. | 2017-12-25 19:23:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:23:54 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:23:57 DTC Client socket (31) | Creating socket. Using TLS 1.2. | 2017-12-25 19:23:57 DTC Client socket (31) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:23:57 DTC Client socket (31) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:24:18 * DTC Client socket (31) | Initiating close of socket by core. | 2017-12-25 19:24:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:24:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:24:18 DTC Client socket (31) | Closed. | 2017-12-25 19:24:18 Bitfinex | Disconnected. | 2017-12-25 19:24:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:24:18 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:24:21 DTC Client socket (33) | Creating socket. Using TLS 1.2. | 2017-12-25 19:24:21 DTC Client socket (33) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:24:21 DTC Client socket (33) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:24:42 * DTC Client socket (33) | Initiating close of socket by core. | 2017-12-25 19:24:42 DTC Client socket (33) | Closed. | 2017-12-25 19:24:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:24:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:24:42 Bitfinex | Disconnected. | 2017-12-25 19:24:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:24:42 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:24:45 DTC Client socket (34) | Creating socket. Using TLS 1.2. | 2017-12-25 19:24:45 DTC Client socket (34) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:24:45 DTC Client socket (34) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:25:06 * DTC Client socket (34) | Initiating close of socket by core. | 2017-12-25 19:25:06 DTC Client socket (34) | Closed. | 2017-12-25 19:25:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:25:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:25:06 Bitfinex | Disconnected. | 2017-12-25 19:25:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:25:06 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:25:09 DTC Client socket (36) | Creating socket. Using TLS 1.2. | 2017-12-25 19:25:09 DTC Client socket (36) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:25:09 DTC Client socket (36) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:25:28 * DTC Client socket (36) | Initiating close of socket by core. | 2017-12-25 19:25:28 DTC Client socket (36) | Closed. | 2017-12-25 19:25:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:25:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:25:28 Bitfinex | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-12-25 19:25:51 Bitfinex | Disconnected. | 2017-12-25 19:25:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:25:51 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:25:54 DTC Client socket (37) | Creating socket. Using TLS 1.2. | 2017-12-25 19:25:54 DTC Client socket (37) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:25:54 DTC Client socket (37) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:26:14 * DTC Client socket (37) | Initiating close of socket by core. | 2017-12-25 19:26:14 DTC Client socket (37) | Closed. | 2017-12-25 19:26:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:26:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:26:14 Bitfinex | Disconnected. | 2017-12-25 19:26:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:26:14 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:26:17 DTC Client socket (39) | Creating socket. Using TLS 1.2. | 2017-12-25 19:26:17 DTC Client socket (39) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:26:17 DTC Client socket (39) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:26:39 * DTC Client socket (39) | Initiating close of socket by core. | 2017-12-25 19:26:39 DTC Client socket (39) | Closed. | 2017-12-25 19:26:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:26:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:26:39 Bitfinex | Disconnected. | 2017-12-25 19:26:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:26:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:26:42 DTC Client socket (40) | Creating socket. Using TLS 1.2. | 2017-12-25 19:26:42 DTC Client socket (40) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:26:42 DTC Client socket (40) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:27:03 * DTC Client socket (40) | Initiating close of socket by core. | 2017-12-25 19:27:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:27:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:27:03 DTC Client socket (40) | Closed. | 2017-12-25 19:27:03 Bitfinex | Disconnected. | 2017-12-25 19:27:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:27:03 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:27:06 DTC Client socket (41) | Creating socket. Using TLS 1.2. | 2017-12-25 19:27:06 DTC Client socket (41) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:27:06 DTC Client socket (41) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:27:27 * DTC Client socket (41) | Initiating close of socket by core. | 2017-12-25 19:27:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:27:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:27:27 DTC Client socket (41) | Closed. | 2017-12-25 19:27:27 Bitfinex | Disconnected. | 2017-12-25 19:27:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:27:27 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:27:29 DTC Client socket (43) | Creating socket. Using TLS 1.2. | 2017-12-25 19:27:29 DTC Client socket (43) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:27:29 DTC Client socket (43) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:27:51 * DTC Client socket (43) | Initiating close of socket by core. | 2017-12-25 19:27:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:27:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:27:51 DTC Client socket (43) | Closed. | 2017-12-25 19:27:51 Bitfinex | Disconnected. | 2017-12-25 19:27:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:27:51 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:27:54 DTC Client socket (44) | Creating socket. Using TLS 1.2. | 2017-12-25 19:27:54 DTC Client socket (44) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:27:54 DTC Client socket (44) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:28:15 * DTC Client socket (44) | Initiating close of socket by core. | 2017-12-25 19:28:15 DTC Client socket (44) | Closed. | 2017-12-25 19:28:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:28:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:28:15 Bitfinex | Disconnected. | 2017-12-25 19:28:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:28:15 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:28:18 DTC Client socket (46) | Creating socket. Using TLS 1.2. | 2017-12-25 19:28:18 DTC Client socket (46) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:28:18 DTC Client socket (46) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:28:39 * DTC Client socket (46) | Initiating close of socket by core. | 2017-12-25 19:28:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:28:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:28:39 DTC Client socket (46) | Closed. | 2017-12-25 19:28:39 Bitfinex | Disconnected. | 2017-12-25 19:28:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:28:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:28:42 DTC Client socket (47) | Creating socket. Using TLS 1.2. | 2017-12-25 19:28:42 DTC Client socket (47) | Connecting to IP: 52.48.47.23. | 2017-12-25 19:28:42 DTC Client socket (47) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-25 19:29:04 * DTC Client socket (47) | Initiating close of socket by core. | 2017-12-25 19:29:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:04 DTC Client socket (47) | Closed. | 2017-12-25 19:29:04 Bitfinex | Disconnected. | 2017-12-25 19:29:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:04 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:07 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:09 * DTC Client socket (48) | Initiating close of socket by core. | 2017-12-25 19:29:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:09 Bitfinex | Disconnected. | 2017-12-25 19:29:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:09 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:12 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:14 * DTC Client socket (50) | Initiating close of socket by core. | 2017-12-25 19:29:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:14 Bitfinex | Disconnected. | 2017-12-25 19:29:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:14 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:17 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:19 * DTC Client socket (51) | Initiating close of socket by core. | 2017-12-25 19:29:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:19 Bitfinex | Disconnected. | 2017-12-25 19:29:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:19 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:23 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:25 * DTC Client socket (52) | Initiating close of socket by core. | 2017-12-25 19:29:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:25 Bitfinex | Disconnected. | 2017-12-25 19:29:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:25 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:28 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:30 * DTC Client socket (53) | Initiating close of socket by core. | 2017-12-25 19:29:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:30 Bitfinex | Disconnected. | 2017-12-25 19:29:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:33 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:35 * DTC Client socket (54) | Initiating close of socket by core. | 2017-12-25 19:29:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:35 Bitfinex | Disconnected. | 2017-12-25 19:29:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:35 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:38 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:41 * DTC Client socket (55) | Initiating close of socket by core. | 2017-12-25 19:29:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:41 Bitfinex | Disconnected. | 2017-12-25 19:29:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:44 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:46 * DTC Client socket (56) | Initiating close of socket by core. | 2017-12-25 19:29:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:46 Bitfinex | Disconnected. | 2017-12-25 19:29:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:46 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:49 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:51 * DTC Client socket (57) | Initiating close of socket by core. | 2017-12-25 19:29:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:51 Bitfinex | Disconnected. | 2017-12-25 19:29:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:51 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:29:54 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:29:56 * DTC Client socket (58) | Initiating close of socket by core. | 2017-12-25 19:29:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:29:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:56 Bitfinex | Disconnected. | 2017-12-25 19:29:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:29:56 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:00 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:02 * DTC Client socket (59) | Initiating close of socket by core. | 2017-12-25 19:30:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:02 Bitfinex | Disconnected. | 2017-12-25 19:30:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:02 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:05 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:07 * DTC Client socket (60) | Initiating close of socket by core. | 2017-12-25 19:30:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:07 Bitfinex | Disconnected. | 2017-12-25 19:30:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:07 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:10 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:12 * DTC Client socket (62) | Initiating close of socket by core. | 2017-12-25 19:30:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:12 Bitfinex | Disconnected. | 2017-12-25 19:30:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:12 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:15 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:17 * DTC Client socket (63) | Initiating close of socket by core. | 2017-12-25 19:30:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:17 Bitfinex | Disconnected. | 2017-12-25 19:30:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:17 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:20 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:23 * DTC Client socket (64) | Initiating close of socket by core. | 2017-12-25 19:30:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:23 Bitfinex | Disconnected. | 2017-12-25 19:30:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:23 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:26 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:28 * DTC Client socket (65) | Initiating close of socket by core. | 2017-12-25 19:30:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:28 Bitfinex | Disconnected. | 2017-12-25 19:30:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:28 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:31 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:34 * DTC Client socket (66) | Initiating close of socket by core. | 2017-12-25 19:30:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:34 Bitfinex | Disconnected. | 2017-12-25 19:30:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:34 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:37 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:39 * DTC Client socket (67) | Initiating close of socket by core. | 2017-12-25 19:30:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:39 Bitfinex | Disconnected. | 2017-12-25 19:30:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:42 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:44 * DTC Client socket (68) | Initiating close of socket by core. | 2017-12-25 19:30:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:44 Bitfinex | Disconnected. | 2017-12-25 19:30:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:44 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:47 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:49 * DTC Client socket (69) | Initiating close of socket by core. | 2017-12-25 19:30:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:49 Bitfinex | Disconnected. | 2017-12-25 19:30:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:49 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:52 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:30:54 * DTC Client socket (70) | Initiating close of socket by core. | 2017-12-25 19:30:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:30:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:54 Bitfinex | Disconnected. | 2017-12-25 19:30:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:30:54 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:30:57 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:31:00 * DTC Client socket (71) | Initiating close of socket by core. | 2017-12-25 19:31:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:31:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:31:00 Bitfinex | Disconnected. | 2017-12-25 19:31:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:31:00 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:33:00 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:33:02 * DTC Client socket (74) | Initiating close of socket by core. | 2017-12-25 19:33:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:33:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:33:02 Bitfinex | Disconnected. | 2017-12-25 19:33:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:33:02 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:35:02 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:35:04 * DTC Client socket (77) | Initiating close of socket by core. | 2017-12-25 19:35:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:35:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:35:04 Bitfinex | Disconnected. | 2017-12-25 19:35:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:35:04 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:37:04 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:37:07 * DTC Client socket (80) | Initiating close of socket by core. | 2017-12-25 19:37:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:37:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:37:07 Bitfinex | Disconnected. | 2017-12-25 19:37:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:37:07 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:39:07 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:39:09 * DTC Client socket (83) | Initiating close of socket by core. | 2017-12-25 19:39:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:39:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:39:09 Bitfinex | Disconnected. | 2017-12-25 19:39:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:39:09 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:41:09 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:41:11 * DTC Client socket (87) | Initiating close of socket by core. | 2017-12-25 19:41:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:41:11 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:41:11 Bitfinex | Disconnected. | 2017-12-25 19:41:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:41:11 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:43:11 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:43:13 * DTC Client socket (90) | Initiating close of socket by core. | 2017-12-25 19:43:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:43:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:43:13 Bitfinex | Disconnected. | 2017-12-25 19:43:13 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:43:13 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:45:14 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:45:16 * DTC Client socket (93) | Initiating close of socket by core. | 2017-12-25 19:45:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:45:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:45:16 Bitfinex | Disconnected. | 2017-12-25 19:45:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:45:16 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:47:32 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:47:35 * DTC Client socket (95) | Initiating close of socket by core. | 2017-12-25 19:47:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:47:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:47:35 Bitfinex | Disconnected. | 2017-12-25 19:47:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:47:35 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:49:34 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:49:37 * DTC Client socket (98) | Initiating close of socket by core. | 2017-12-25 19:49:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:49:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:49:37 Bitfinex | Disconnected. | 2017-12-25 19:49:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:49:37 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:51:36 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:51:39 * DTC Client socket (101) | Initiating close of socket by core. | 2017-12-25 19:51:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:51:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:51:39 Bitfinex | Disconnected. | 2017-12-25 19:51:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:51:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:53:39 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:53:41 * DTC Client socket (104) | Initiating close of socket by core. | 2017-12-25 19:53:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:53:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:53:41 Bitfinex | Disconnected. | 2017-12-25 19:53:41 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:53:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:55:41 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:55:43 * DTC Client socket (107) | Initiating close of socket by core. | 2017-12-25 19:55:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:55:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:55:43 Bitfinex | Disconnected. | 2017-12-25 19:55:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:55:43 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:57:44 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:57:46 * DTC Client socket (110) | Initiating close of socket by core. | 2017-12-25 19:57:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:57:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:57:46 Bitfinex | Disconnected. | 2017-12-25 19:57:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:57:46 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 19:59:46 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 19:59:48 * DTC Client socket (113) | Initiating close of socket by core. | 2017-12-25 19:59:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 19:59:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:59:48 Bitfinex | Disconnected. | 2017-12-25 19:59:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 19:59:48 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:01:48 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:01:50 * DTC Client socket (116) | Initiating close of socket by core. | 2017-12-25 20:01:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:01:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:01:50 Bitfinex | Disconnected. | 2017-12-25 20:01:50 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:01:50 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:03:50 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:03:53 * DTC Client socket (119) | Initiating close of socket by core. | 2017-12-25 20:03:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:03:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:03:53 Bitfinex | Disconnected. | 2017-12-25 20:03:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:03:53 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:05:53 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:05:55 * DTC Client socket (122) | Initiating close of socket by core. | 2017-12-25 20:05:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:05:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:05:55 Bitfinex | Disconnected. | 2017-12-25 20:05:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:05:55 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:07:55 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:07:57 * DTC Client socket (125) | Initiating close of socket by core. | 2017-12-25 20:07:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:07:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:07:57 Bitfinex | Disconnected. | 2017-12-25 20:07:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:07:57 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:10:05 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:10:07 * DTC Client socket (128) | Initiating close of socket by core. | 2017-12-25 20:10:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:10:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:10:07 Bitfinex | Disconnected. | 2017-12-25 20:10:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:10:07 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:12:07 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:12:09 * DTC Client socket (131) | Initiating close of socket by core. | 2017-12-25 20:12:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:12:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:12:09 Bitfinex | Disconnected. | 2017-12-25 20:12:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:12:09 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:14:10 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:14:12 * DTC Client socket (135) | Initiating close of socket by core. | 2017-12-25 20:14:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:14:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:14:12 Bitfinex | Disconnected. | 2017-12-25 20:14:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:14:12 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:16:12 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:16:14 * DTC Client socket (138) | Initiating close of socket by core. | 2017-12-25 20:16:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:16:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:16:14 Bitfinex | Disconnected. | 2017-12-25 20:16:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:16:14 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:18:14 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:18:16 * DTC Client socket (141) | Initiating close of socket by core. | 2017-12-25 20:18:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:18:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:18:16 Bitfinex | Disconnected. | 2017-12-25 20:18:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:18:16 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:20:16 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:20:19 * DTC Client socket (144) | Initiating close of socket by core. | 2017-12-25 20:20:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:20:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:20:19 Bitfinex | Disconnected. | 2017-12-25 20:20:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:20:19 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:22:18 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:22:21 * DTC Client socket (147) | Initiating close of socket by core. | 2017-12-25 20:22:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:22:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:22:21 Bitfinex | Disconnected. | 2017-12-25 20:22:21 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:22:21 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:24:21 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:24:23 * DTC Client socket (150) | Initiating close of socket by core. | 2017-12-25 20:24:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:24:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:24:23 Bitfinex | Disconnected. | 2017-12-25 20:24:23 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:24:23 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:26:23 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:26:25 * DTC Client socket (153) | Initiating close of socket by core. | 2017-12-25 20:26:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:26:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:26:25 Bitfinex | Disconnected. | 2017-12-25 20:26:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:26:25 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:28:26 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:28:28 * DTC Client socket (156) | Initiating close of socket by core. | 2017-12-25 20:28:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:28:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:28:28 Bitfinex | Disconnected. | 2017-12-25 20:28:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:28:28 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:30:28 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:30:30 * DTC Client socket (159) | Initiating close of socket by core. | 2017-12-25 20:30:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:30:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:30:30 Bitfinex | Disconnected. | 2017-12-25 20:30:30 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:30:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:32:30 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:32:32 * DTC Client socket (162) | Initiating close of socket by core. | 2017-12-25 20:32:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:32:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:32:32 Bitfinex | Disconnected. | 2017-12-25 20:32:33 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:32:33 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:34:32 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:34:35 * DTC Client socket (165) | Initiating close of socket by core. | 2017-12-25 20:34:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:34:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:34:35 Bitfinex | Disconnected. | 2017-12-25 20:34:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:34:35 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:36:34 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:36:37 * DTC Client socket (168) | Initiating close of socket by core. | 2017-12-25 20:36:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:36:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:36:37 Bitfinex | Disconnected. | 2017-12-25 20:36:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:36:37 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:38:37 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:38:39 * DTC Client socket (171) | Initiating close of socket by core. | 2017-12-25 20:38:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:38:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:38:39 Bitfinex | Disconnected. | 2017-12-25 20:38:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:38:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:40:39 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:40:41 * DTC Client socket (174) | Initiating close of socket by core. | 2017-12-25 20:40:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:40:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:40:41 Bitfinex | Disconnected. | 2017-12-25 20:40:41 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:40:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:42:42 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:42:44 * DTC Client socket (177) | Initiating close of socket by core. | 2017-12-25 20:42:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:42:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:42:44 Bitfinex | Disconnected. | 2017-12-25 20:42:44 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:42:44 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:44:44 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:44:46 * DTC Client socket (180) | Initiating close of socket by core. | 2017-12-25 20:44:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:44:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:44:46 Bitfinex | Disconnected. | 2017-12-25 20:44:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:44:46 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:46:46 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:46:48 * DTC Client socket (183) | Initiating close of socket by core. | 2017-12-25 20:46:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:46:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:46:48 Bitfinex | Disconnected. | 2017-12-25 20:46:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:46:48 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:48:48 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:48:51 * DTC Client socket (187) | Initiating close of socket by core. | 2017-12-25 20:48:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:48:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:48:51 Bitfinex | Disconnected. | 2017-12-25 20:48:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:48:51 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:50:51 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:50:53 * DTC Client socket (190) | Initiating close of socket by core. | 2017-12-25 20:50:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:50:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:50:53 Bitfinex | Disconnected. | 2017-12-25 20:50:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:50:53 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:52:53 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:52:55 * DTC Client socket (193) | Initiating close of socket by core. | 2017-12-25 20:52:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:52:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:52:55 Bitfinex | Disconnected. | 2017-12-25 20:52:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:52:55 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:54:55 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:54:58 * DTC Client socket (196) | Initiating close of socket by core. | 2017-12-25 20:54:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:54:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:54:58 Bitfinex | Disconnected. | 2017-12-25 20:54:58 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:54:58 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:56:58 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:57:00 * DTC Client socket (199) | Initiating close of socket by core. | 2017-12-25 20:57:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:57:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:57:00 Bitfinex | Disconnected. | 2017-12-25 20:57:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:57:00 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 20:59:00 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 20:59:02 * DTC Client socket (202) | Initiating close of socket by core. | 2017-12-25 20:59:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 20:59:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:59:02 Bitfinex | Disconnected. | 2017-12-25 20:59:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 20:59:02 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:01:02 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:01:04 * DTC Client socket (205) | Initiating close of socket by core. | 2017-12-25 21:01:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:01:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:01:04 Bitfinex | Disconnected. | 2017-12-25 21:01:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:01:04 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:03:04 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:03:06 * DTC Client socket (208) | Initiating close of socket by core. | 2017-12-25 21:03:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:03:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:03:06 Bitfinex | Disconnected. | 2017-12-25 21:03:06 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:03:06 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:05:07 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:05:09 * DTC Client socket (211) | Initiating close of socket by core. | 2017-12-25 21:05:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:05:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:05:09 Bitfinex | Disconnected. | 2017-12-25 21:05:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:05:09 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:07:09 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:07:11 * DTC Client socket (214) | Initiating close of socket by core. | 2017-12-25 21:07:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:07:11 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:07:11 Bitfinex | Disconnected. | 2017-12-25 21:07:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:07:11 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:09:11 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:09:13 * DTC Client socket (218) | Initiating close of socket by core. | 2017-12-25 21:09:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:09:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:09:13 Bitfinex | Disconnected. | 2017-12-25 21:09:13 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:09:13 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:11:13 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:11:15 * DTC Client socket (221) | Initiating close of socket by core. | 2017-12-25 21:11:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:11:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:11:15 Bitfinex | Disconnected. | 2017-12-25 21:11:15 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:11:15 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:13:16 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:13:18 * DTC Client socket (224) | Initiating close of socket by core. | 2017-12-25 21:13:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:13:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:13:18 Bitfinex | Disconnected. | 2017-12-25 21:13:18 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:13:18 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:15:18 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:15:20 * DTC Client socket (227) | Initiating close of socket by core. | 2017-12-25 21:15:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:15:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:15:20 Bitfinex | Disconnected. | 2017-12-25 21:15:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:15:20 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:17:20 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:17:23 * DTC Client socket (230) | Initiating close of socket by core. | 2017-12-25 21:17:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:17:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:17:23 Bitfinex | Disconnected. | 2017-12-25 21:17:23 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:17:23 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:19:22 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:19:25 * DTC Client socket (233) | Initiating close of socket by core. | 2017-12-25 21:19:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:19:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:19:25 Bitfinex | Disconnected. | 2017-12-25 21:19:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:19:25 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:21:25 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:21:27 * DTC Client socket (236) | Initiating close of socket by core. | 2017-12-25 21:21:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:21:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:21:27 Bitfinex | Disconnected. | 2017-12-25 21:21:27 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:21:27 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:23:27 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:23:29 * DTC Client socket (239) | Initiating close of socket by core. | 2017-12-25 21:23:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:23:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:23:29 Bitfinex | Disconnected. | 2017-12-25 21:23:29 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:23:29 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:25:29 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:25:32 * DTC Client socket (242) | Initiating close of socket by core. | 2017-12-25 21:25:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:25:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:25:32 Bitfinex | Disconnected. | 2017-12-25 21:25:32 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:25:32 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:27:32 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:27:34 * DTC Client socket (245) | Initiating close of socket by core. | 2017-12-25 21:27:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:27:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:27:34 Bitfinex | Disconnected. | 2017-12-25 21:27:34 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:27:34 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:29:34 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:29:36 * DTC Client socket (248) | Initiating close of socket by core. | 2017-12-25 21:29:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:29:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:29:36 Bitfinex | Disconnected. | 2017-12-25 21:29:36 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:29:36 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:31:36 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:31:39 * DTC Client socket (251) | Initiating close of socket by core. | 2017-12-25 21:31:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:31:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:31:39 Bitfinex | Disconnected. | 2017-12-25 21:31:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:31:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:33:38 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:33:41 * DTC Client socket (254) | Initiating close of socket by core. | 2017-12-25 21:33:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:33:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:33:41 Bitfinex | Disconnected. | 2017-12-25 21:33:41 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:33:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:35:41 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:35:43 * DTC Client socket (257) | Initiating close of socket by core. | 2017-12-25 21:35:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:35:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:35:43 Bitfinex | Disconnected. | 2017-12-25 21:35:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:35:43 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:37:43 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:37:45 * DTC Client socket (260) | Initiating close of socket by core. | 2017-12-25 21:37:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:37:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:37:45 Bitfinex | Disconnected. | 2017-12-25 21:37:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:37:45 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:39:46 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:39:48 * DTC Client socket (263) | Initiating close of socket by core. | 2017-12-25 21:39:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:39:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:39:48 Bitfinex | Disconnected. | 2017-12-25 21:39:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:39:48 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:41:48 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:41:50 * DTC Client socket (266) | Initiating close of socket by core. | 2017-12-25 21:41:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:41:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:41:50 Bitfinex | Disconnected. | 2017-12-25 21:41:50 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:41:50 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:43:50 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:43:52 * DTC Client socket (269) | Initiating close of socket by core. | 2017-12-25 21:43:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:43:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:43:52 Bitfinex | Disconnected. | 2017-12-25 21:43:52 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:43:52 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:45:59 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:46:00 * DTC Client socket (272) | Initiating close of socket by core. | 2017-12-25 21:46:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:46:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:46:00 Bitfinex | Disconnected. | 2017-12-25 21:46:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:46:00 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:48:01 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:48:03 * DTC Client socket (275) | Initiating close of socket by core. | 2017-12-25 21:48:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:48:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:48:03 Bitfinex | Disconnected. | 2017-12-25 21:48:03 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:48:03 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:50:03 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:50:05 * DTC Client socket (278) | Initiating close of socket by core. | 2017-12-25 21:50:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:50:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:50:05 Bitfinex | Disconnected. | 2017-12-25 21:50:05 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:50:05 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:52:05 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:52:07 * DTC Client socket (281) | Initiating close of socket by core. | 2017-12-25 21:52:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:52:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:52:07 Bitfinex | Disconnected. | 2017-12-25 21:52:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:52:07 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:54:07 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:54:10 * DTC Client socket (284) | Initiating close of socket by core. | 2017-12-25 21:54:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:54:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:54:10 Bitfinex | Disconnected. | 2017-12-25 21:54:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:54:10 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:56:10 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:56:12 * DTC Client socket (287) | Initiating close of socket by core. | 2017-12-25 21:56:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:56:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:56:12 Bitfinex | Disconnected. | 2017-12-25 21:56:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:56:12 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 21:58:12 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 21:58:14 * DTC Client socket (291) | Initiating close of socket by core. | 2017-12-25 21:58:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 21:58:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:58:14 Bitfinex | Disconnected. | 2017-12-25 21:58:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 21:58:14 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:00:14 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:00:16 * DTC Client socket (294) | Initiating close of socket by core. | 2017-12-25 22:00:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:00:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:00:16 Bitfinex | Disconnected. | 2017-12-25 22:00:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:00:16 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:02:17 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:02:19 * DTC Client socket (297) | Initiating close of socket by core. | 2017-12-25 22:02:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:02:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:02:19 Bitfinex | Disconnected. | 2017-12-25 22:02:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:02:19 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:04:19 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:04:21 * DTC Client socket (300) | Initiating close of socket by core. | 2017-12-25 22:04:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:04:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:04:21 Bitfinex | Disconnected. | 2017-12-25 22:04:21 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:04:21 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:06:21 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:06:24 * DTC Client socket (303) | Initiating close of socket by core. | 2017-12-25 22:06:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:06:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:06:24 Bitfinex | Disconnected. | 2017-12-25 22:06:24 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:06:24 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:08:23 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:08:26 * DTC Client socket (306) | Initiating close of socket by core. | 2017-12-25 22:08:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:08:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:08:26 Bitfinex | Disconnected. | 2017-12-25 22:08:26 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:08:26 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:10:25 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:10:28 * DTC Client socket (309) | Initiating close of socket by core. | 2017-12-25 22:10:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:10:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:10:28 Bitfinex | Disconnected. | 2017-12-25 22:10:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:10:28 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:12:28 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:12:30 * DTC Client socket (312) | Initiating close of socket by core. | 2017-12-25 22:12:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:12:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:12:30 Bitfinex | Disconnected. | 2017-12-25 22:12:30 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:12:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:14:30 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:14:32 * DTC Client socket (315) | Initiating close of socket by core. | 2017-12-25 22:14:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:14:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:14:32 Bitfinex | Disconnected. | 2017-12-25 22:14:32 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:14:32 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:16:33 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:16:35 * DTC Client socket (318) | Initiating close of socket by core. | 2017-12-25 22:16:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:16:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:16:35 Bitfinex | Disconnected. | 2017-12-25 22:16:35 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:16:35 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:18:35 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:18:37 * DTC Client socket (322) | Initiating close of socket by core. | 2017-12-25 22:18:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:18:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:18:37 Bitfinex | Disconnected. | 2017-12-25 22:18:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:18:37 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:20:37 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:20:39 * DTC Client socket (325) | Initiating close of socket by core. | 2017-12-25 22:20:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:20:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:20:39 Bitfinex | Disconnected. | 2017-12-25 22:20:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:20:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:22:39 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:22:42 * DTC Client socket (328) | Initiating close of socket by core. | 2017-12-25 22:22:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:22:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:22:42 Bitfinex | Disconnected. | 2017-12-25 22:22:42 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:22:42 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:24:42 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:24:44 * DTC Client socket (331) | Initiating close of socket by core. | 2017-12-25 22:24:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:24:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:24:44 Bitfinex | Disconnected. | 2017-12-25 22:24:44 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:24:44 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:26:44 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:26:46 * DTC Client socket (334) | Initiating close of socket by core. | 2017-12-25 22:26:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:26:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:26:46 Bitfinex | Disconnected. | 2017-12-25 22:26:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:26:46 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:28:46 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:28:48 * DTC Client socket (337) | Initiating close of socket by core. | 2017-12-25 22:28:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:28:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:28:48 Bitfinex | Disconnected. | 2017-12-25 22:28:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:28:48 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:30:49 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:30:51 * DTC Client socket (340) | Initiating close of socket by core. | 2017-12-25 22:30:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:30:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:30:51 Bitfinex | Disconnected. | 2017-12-25 22:30:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:30:51 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:32:51 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:32:53 * DTC Client socket (343) | Initiating close of socket by core. | 2017-12-25 22:32:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:32:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:32:53 Bitfinex | Disconnected. | 2017-12-25 22:32:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:32:53 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:34:53 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:34:55 * DTC Client socket (346) | Initiating close of socket by core. | 2017-12-25 22:34:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:34:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:34:55 Bitfinex | Disconnected. | 2017-12-25 22:34:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:34:55 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:36:55 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:36:57 * DTC Client socket (349) | Initiating close of socket by core. | 2017-12-25 22:36:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:36:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:36:57 Bitfinex | Disconnected. | 2017-12-25 22:36:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:36:57 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:38:58 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:39:00 * DTC Client socket (352) | Initiating close of socket by core. | 2017-12-25 22:39:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:39:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:39:00 Bitfinex | Disconnected. | 2017-12-25 22:39:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:39:00 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:41:00 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:41:02 * DTC Client socket (355) | Initiating close of socket by core. | 2017-12-25 22:41:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:41:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:41:02 Bitfinex | Disconnected. | 2017-12-25 22:41:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:41:02 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:43:02 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:43:05 * DTC Client socket (358) | Initiating close of socket by core. | 2017-12-25 22:43:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:43:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:43:05 Bitfinex | Disconnected. | 2017-12-25 22:43:05 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:43:05 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:45:04 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:45:07 * DTC Client socket (361) | Initiating close of socket by core. | 2017-12-25 22:45:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:45:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:45:07 Bitfinex | Disconnected. | 2017-12-25 22:45:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:45:07 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:47:07 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:47:09 * DTC Client socket (364) | Initiating close of socket by core. | 2017-12-25 22:47:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:47:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:47:09 Bitfinex | Disconnected. | 2017-12-25 22:47:09 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:47:09 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:49:09 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:49:11 * DTC Client socket (367) | Initiating close of socket by core. | 2017-12-25 22:49:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:49:11 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:49:11 Bitfinex | Disconnected. | 2017-12-25 22:49:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:49:11 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:51:12 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:51:14 * DTC Client socket (371) | Initiating close of socket by core. | 2017-12-25 22:51:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:51:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:51:14 Bitfinex | Disconnected. | 2017-12-25 22:51:14 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:51:14 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:53:14 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:53:16 * DTC Client socket (374) | Initiating close of socket by core. | 2017-12-25 22:53:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:53:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:53:16 Bitfinex | Disconnected. | 2017-12-25 22:53:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:53:16 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:55:16 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:55:18 * DTC Client socket (377) | Initiating close of socket by core. | 2017-12-25 22:55:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:55:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:55:18 Bitfinex | Disconnected. | 2017-12-25 22:55:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:55:19 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:57:18 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:57:21 * DTC Client socket (380) | Initiating close of socket by core. | 2017-12-25 22:57:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:57:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:57:21 Bitfinex | Disconnected. | 2017-12-25 22:57:21 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:57:21 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 22:59:20 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 22:59:23 * DTC Client socket (383) | Initiating close of socket by core. | 2017-12-25 22:59:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 22:59:23 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:59:23 Bitfinex | Disconnected. | 2017-12-25 22:59:23 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 22:59:23 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:01:23 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:01:25 * DTC Client socket (386) | Initiating close of socket by core. | 2017-12-25 23:01:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:01:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:01:25 Bitfinex | Disconnected. | 2017-12-25 23:01:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:01:25 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:03:25 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:03:27 * DTC Client socket (389) | Initiating close of socket by core. | 2017-12-25 23:03:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:03:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:03:27 Bitfinex | Disconnected. | 2017-12-25 23:03:27 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:03:27 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:05:28 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:05:30 * DTC Client socket (392) | Initiating close of socket by core. | 2017-12-25 23:05:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:05:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:05:30 Bitfinex | Disconnected. | 2017-12-25 23:05:30 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:05:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:07:30 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:07:32 * DTC Client socket (395) | Initiating close of socket by core. | 2017-12-25 23:07:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:07:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:07:32 Bitfinex | Disconnected. | 2017-12-25 23:07:32 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:07:32 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:09:32 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:09:34 * DTC Client socket (398) | Initiating close of socket by core. | 2017-12-25 23:09:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:09:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:09:34 Bitfinex | Disconnected. | 2017-12-25 23:09:34 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:09:34 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:11:34 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:11:37 * DTC Client socket (401) | Initiating close of socket by core. | 2017-12-25 23:11:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:11:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:11:37 Bitfinex | Disconnected. | 2017-12-25 23:11:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:11:37 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:13:36 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:13:39 * DTC Client socket (404) | Initiating close of socket by core. | 2017-12-25 23:13:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:13:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:13:39 Bitfinex | Disconnected. | 2017-12-25 23:13:39 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:13:39 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:15:39 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:15:41 * DTC Client socket (407) | Initiating close of socket by core. | 2017-12-25 23:15:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:15:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:15:41 Bitfinex | Disconnected. | 2017-12-25 23:15:41 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:15:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:17:41 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:17:43 * DTC Client socket (410) | Initiating close of socket by core. | 2017-12-25 23:17:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:17:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:17:43 Bitfinex | Disconnected. | 2017-12-25 23:17:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:17:43 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:19:44 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:19:46 * DTC Client socket (413) | Initiating close of socket by core. | 2017-12-25 23:19:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:19:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:19:46 Bitfinex | Disconnected. | 2017-12-25 23:19:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:19:46 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:21:46 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:21:48 * DTC Client socket (416) | Initiating close of socket by core. | 2017-12-25 23:21:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:21:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:21:48 Bitfinex | Disconnected. | 2017-12-25 23:21:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:21:48 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:23:48 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:23:50 * DTC Client socket (419) | Initiating close of socket by core. | 2017-12-25 23:23:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:23:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:23:50 Bitfinex | Disconnected. | 2017-12-25 23:23:50 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:23:50 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:25:50 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:25:52 * DTC Client socket (422) | Initiating close of socket by core. | 2017-12-25 23:25:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:25:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:25:52 Bitfinex | Disconnected. | 2017-12-25 23:25:52 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:25:52 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:27:53 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:27:55 * DTC Client socket (425) | Initiating close of socket by core. | 2017-12-25 23:27:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:27:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:27:55 Bitfinex | Disconnected. | 2017-12-25 23:27:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:27:55 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:29:55 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:29:57 * DTC Client socket (428) | Initiating close of socket by core. | 2017-12-25 23:29:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:29:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:29:57 Bitfinex | Disconnected. | 2017-12-25 23:29:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:29:57 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:31:57 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:32:00 * DTC Client socket (431) | Initiating close of socket by core. | 2017-12-25 23:32:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:32:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:32:00 Bitfinex | Disconnected. | 2017-12-25 23:32:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:32:00 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:33:59 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:34:02 * DTC Client socket (434) | Initiating close of socket by core. | 2017-12-25 23:34:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-25 23:34:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:34:02 Bitfinex | Disconnected. | 2017-12-25 23:34:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:34:02 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-25 23:34:57 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-25 23:34:57 * Notice: Detected that the system has resumed from a low-power state. | 2017-12-25 23:34:57 Re-connecting to the Data/Trading service. | 2017-12-25 23:34:57 DTC Client socket (436) | Initiating close of socket by core. | 2017-12-25 23:34:57 Bitfinex | Disconnected. | 2017-12-25 23:34:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-25 23:34:57 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:06 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:09 * DTC Client socket (439) | Initiating close of socket by core. | 2017-12-29 00:59:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:09 Bitfinex | Disconnected. | 2017-12-29 00:59:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:09 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:12 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:12 * DTC Client socket (440) | Initiating close of socket by core. | 2017-12-29 00:59:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:12 Bitfinex | Disconnected. | 2017-12-29 00:59:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:16 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:19 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:21 * DTC Client socket (441) | Initiating close of socket by core. | 2017-12-29 00:59:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:21 Bitfinex | Disconnected. | 2017-12-29 00:59:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:21 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:24 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:27 * DTC Client socket (442) | Initiating close of socket by core. | 2017-12-29 00:59:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:27 Bitfinex | Disconnected. | 2017-12-29 00:59:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:27 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:30 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:32 * DTC Client socket (443) | Initiating close of socket by core. | 2017-12-29 00:59:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:32 Bitfinex | Disconnected. | 2017-12-29 00:59:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:32 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:35 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:37 * DTC Client socket (444) | Initiating close of socket by core. | 2017-12-29 00:59:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:37 Bitfinex | Disconnected. | 2017-12-29 00:59:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:37 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:40 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:43 * DTC Client socket (445) | Initiating close of socket by core. | 2017-12-29 00:59:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:43 Bitfinex | Disconnected. | 2017-12-29 00:59:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:43 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:46 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:48 * DTC Client socket (446) | Initiating close of socket by core. | 2017-12-29 00:59:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:48 Bitfinex | Disconnected. | 2017-12-29 00:59:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:48 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:51 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:53 * DTC Client socket (447) | Initiating close of socket by core. | 2017-12-29 00:59:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:53 Bitfinex | Disconnected. | 2017-12-29 00:59:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:53 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 00:59:56 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 00:59:58 * DTC Client socket (448) | Initiating close of socket by core. | 2017-12-29 00:59:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 00:59:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:58 Bitfinex | Disconnected. | 2017-12-29 00:59:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 00:59:58 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:00:01 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 01:00:04 * DTC Client socket (450) | Initiating close of socket by core. | 2017-12-29 01:00:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:00:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:00:04 Bitfinex | Disconnected. | 2017-12-29 01:00:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:00:04 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:00:06 Error getting address info for dtc.bitsouk.com. Windows error code 11001: No such host is known. | 2017-12-29 01:00:09 * DTC Client socket (451) | Initiating close of socket by core. | 2017-12-29 01:00:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:00:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:00:09 Bitfinex | Disconnected. | 2017-12-29 01:00:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:00:09 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:00:12 DTC Client socket (452) | Creating socket. Using TLS 1.2. | 2017-12-29 01:00:13 DTC Client socket (452) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:00:16 DTC Client socket (452) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:00:38 * DTC Client socket (452) | Initiating close of socket by core. | 2017-12-29 01:00:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:00:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:00:38 Bitfinex | Disconnected. | 2017-12-29 01:00:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:00:38 DTC Client socket (452) | Closed. | 2017-12-29 01:00:38 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:00:41 DTC Client socket (453) | Creating socket. Using TLS 1.2. | 2017-12-29 01:00:41 DTC Client socket (453) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:00:41 DTC Client socket (453) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:01:04 * DTC Client socket (453) | Initiating close of socket by core. | 2017-12-29 01:01:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:01:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:01:04 DTC Client socket (453) | Closed. | 2017-12-29 01:01:04 Bitfinex | Disconnected. | 2017-12-29 01:01:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:01:04 Sierra Chart account data changed. Requesting updated account information. | 2017-12-29 01:01:04 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:01:07 DTC Client socket (456) | Creating socket. Using TLS 1.2. | 2017-12-29 01:01:07 DTC Client socket (456) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:01:07 Successfully processed Sierra Chart account data. | 2017-12-29 01:01:11 HTTPS connection to www.sierrachart.com:443 (457) | Creating socket. Using TLS 1.2. | 2017-12-29 01:01:12 HTTPS connection to www.sierrachart.com:443 (457) | Connecting to IP: 204.15.192.108. | 2017-12-29 01:01:12 HTTPS connection to www.sierrachart.com:443 (457) | Socket gracefully closed by remote side. | 2017-12-29 01:01:18 HTTPS connection to www.sierrachart.com:443 (457) | Received socket Close event. | 2017-12-29 01:01:18 HTTPS connection to www.sierrachart.com:443 (457) | Initiating close of socket by core. | 2017-12-29 01:01:18 HTTPS connection to www.sierrachart.com:443 (457) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-12-29 01:01:18 HTTPS connection to www.sierrachart.com:443 (457) | Closed. | 2017-12-29 01:01:18 DTC Client socket (456) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:01:28 * DTC Client socket (456) | Initiating close of socket by core. | 2017-12-29 01:01:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:01:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:01:28 DTC Client socket (456) | Closed. | 2017-12-29 01:01:28 Bitfinex | Disconnected. | 2017-12-29 01:01:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:01:28 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:01:31 DTC Client socket (458) | Creating socket. Using TLS 1.2. | 2017-12-29 01:01:31 DTC Client socket (458) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:01:31 DTC Client socket (458) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:01:52 * DTC Client socket (458) | Initiating close of socket by core. | 2017-12-29 01:01:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:01:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:01:52 DTC Client socket (458) | Closed. | 2017-12-29 01:01:52 Bitfinex | Disconnected. | 2017-12-29 01:01:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:01:52 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:01:55 DTC Client socket (459) | Creating socket. Using TLS 1.2. | 2017-12-29 01:01:55 DTC Client socket (459) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:01:55 DTC Client socket (459) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:02:16 * DTC Client socket (459) | Initiating close of socket by core. | 2017-12-29 01:02:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:02:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:02:16 DTC Client socket (459) | Closed. | 2017-12-29 01:02:16 Bitfinex | Disconnected. | 2017-12-29 01:02:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:02:16 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:02:19 DTC Client socket (461) | Creating socket. Using TLS 1.2. | 2017-12-29 01:02:19 DTC Client socket (461) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:02:19 DTC Client socket (461) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:02:40 * DTC Client socket (461) | Initiating close of socket by core. | 2017-12-29 01:02:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:02:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:02:40 DTC Client socket (461) | Closed. | 2017-12-29 01:02:40 Bitfinex | Disconnected. | 2017-12-29 01:02:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:02:40 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:02:43 DTC Client socket (462) | Creating socket. Using TLS 1.2. | 2017-12-29 01:02:43 DTC Client socket (462) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:02:43 DTC Client socket (462) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:03:04 * DTC Client socket (462) | Initiating close of socket by core. | 2017-12-29 01:03:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:03:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:03:04 DTC Client socket (462) | Closed. | 2017-12-29 01:03:04 Bitfinex | Disconnected. | 2017-12-29 01:03:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:03:04 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:03:07 DTC Client socket (464) | Creating socket. Using TLS 1.2. | 2017-12-29 01:03:07 DTC Client socket (464) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:03:07 DTC Client socket (464) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:03:28 * DTC Client socket (464) | Initiating close of socket by core. | 2017-12-29 01:03:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:03:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:03:28 DTC Client socket (464) | Closed. | 2017-12-29 01:03:28 Bitfinex | Disconnected. | 2017-12-29 01:03:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:03:28 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:03:32 DTC Client socket (465) | Creating socket. Using TLS 1.2. | 2017-12-29 01:03:32 DTC Client socket (465) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:03:32 DTC Client socket (465) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:03:52 * DTC Client socket (465) | Initiating close of socket by core. | 2017-12-29 01:03:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:03:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:03:52 DTC Client socket (465) | Closed. | 2017-12-29 01:03:52 Bitfinex | Disconnected. | 2017-12-29 01:03:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:03:52 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:03:55 DTC Client socket (466) | Creating socket. Using TLS 1.2. | 2017-12-29 01:03:55 DTC Client socket (466) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:03:55 DTC Client socket (466) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:04:17 * DTC Client socket (466) | Initiating close of socket by core. | 2017-12-29 01:04:17 DTC Client socket (466) | Closed. | 2017-12-29 01:04:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:04:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:04:17 Bitfinex | Disconnected. | 2017-12-29 01:04:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:04:17 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:04:19 DTC Client socket (468) | Creating socket. Using TLS 1.2. | 2017-12-29 01:04:19 DTC Client socket (468) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:04:19 DTC Client socket (468) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:04:41 * DTC Client socket (468) | Initiating close of socket by core. | 2017-12-29 01:04:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:04:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:04:41 DTC Client socket (468) | Closed. | 2017-12-29 01:04:41 Bitfinex | Disconnected. | 2017-12-29 01:04:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:04:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:04:44 DTC Client socket (469) | Creating socket. Using TLS 1.2. | 2017-12-29 01:04:44 DTC Client socket (469) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:04:44 DTC Client socket (469) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:05:05 * DTC Client socket (469) | Initiating close of socket by core. | 2017-12-29 01:05:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:05:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:05:05 DTC Client socket (469) | Closed. | 2017-12-29 01:05:05 Bitfinex | Disconnected. | 2017-12-29 01:05:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:05:05 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:05:07 DTC Client socket (471) | Creating socket. Using TLS 1.2. | 2017-12-29 01:05:07 DTC Client socket (471) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:05:07 DTC Client socket (471) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:05:29 * DTC Client socket (471) | Initiating close of socket by core. | 2017-12-29 01:05:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:05:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:05:29 DTC Client socket (471) | Closed. | 2017-12-29 01:05:29 Bitfinex | Disconnected. | 2017-12-29 01:05:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:05:29 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:05:32 DTC Client socket (472) | Creating socket. Using TLS 1.2. | 2017-12-29 01:05:32 DTC Client socket (472) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:05:32 DTC Client socket (472) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:05:53 * DTC Client socket (472) | Initiating close of socket by core. | 2017-12-29 01:05:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:05:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:05:53 DTC Client socket (472) | Closed. | 2017-12-29 01:05:53 Bitfinex | Disconnected. | 2017-12-29 01:05:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:05:53 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:05:56 DTC Client socket (473) | Creating socket. Using TLS 1.2. | 2017-12-29 01:05:56 DTC Client socket (473) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:05:56 DTC Client socket (473) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:06:17 * DTC Client socket (473) | Initiating close of socket by core. | 2017-12-29 01:06:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:06:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:06:17 DTC Client socket (473) | Closed. | 2017-12-29 01:06:17 Bitfinex | Disconnected. | 2017-12-29 01:06:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:06:17 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:06:20 DTC Client socket (475) | Creating socket. Using TLS 1.2. | 2017-12-29 01:06:20 DTC Client socket (475) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:06:20 DTC Client socket (475) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:06:41 * DTC Client socket (475) | Initiating close of socket by core. | 2017-12-29 01:06:41 DTC Client socket (475) | Closed. | 2017-12-29 01:06:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:06:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:06:41 Bitfinex | Disconnected. | 2017-12-29 01:06:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:06:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:06:44 DTC Client socket (476) | Creating socket. Using TLS 1.2. | 2017-12-29 01:06:44 DTC Client socket (476) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:06:44 DTC Client socket (476) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:07:05 * DTC Client socket (476) | Initiating close of socket by core. | 2017-12-29 01:07:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:07:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:07:05 DTC Client socket (476) | Closed. | 2017-12-29 01:07:05 Bitfinex | Disconnected. | 2017-12-29 01:07:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:07:05 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:07:08 DTC Client socket (478) | Creating socket. Using TLS 1.2. | 2017-12-29 01:07:08 DTC Client socket (478) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:07:08 DTC Client socket (478) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:07:29 * DTC Client socket (478) | Initiating close of socket by core. | 2017-12-29 01:07:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:07:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:07:29 DTC Client socket (478) | Closed. | 2017-12-29 01:07:29 Bitfinex | Disconnected. | 2017-12-29 01:07:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:07:29 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:07:32 DTC Client socket (479) | Creating socket. Using TLS 1.2. | 2017-12-29 01:07:32 DTC Client socket (479) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:07:32 DTC Client socket (479) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:07:53 * DTC Client socket (479) | Initiating close of socket by core. | 2017-12-29 01:07:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:07:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:07:53 DTC Client socket (479) | Closed. | 2017-12-29 01:07:53 Bitfinex | Disconnected. | 2017-12-29 01:07:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:07:53 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:07:56 DTC Client socket (480) | Creating socket. Using TLS 1.2. | 2017-12-29 01:07:56 DTC Client socket (480) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:07:56 DTC Client socket (480) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:08:17 * DTC Client socket (480) | Initiating close of socket by core. | 2017-12-29 01:08:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:08:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:08:17 DTC Client socket (480) | Closed. | 2017-12-29 01:08:17 Bitfinex | Disconnected. | 2017-12-29 01:08:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:08:17 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:08:20 DTC Client socket (482) | Creating socket. Using TLS 1.2. | 2017-12-29 01:08:20 DTC Client socket (482) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:08:20 DTC Client socket (482) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:08:41 * DTC Client socket (482) | Initiating close of socket by core. | 2017-12-29 01:08:41 DTC Client socket (482) | Closed. | 2017-12-29 01:08:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:08:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:08:41 Bitfinex | Disconnected. | 2017-12-29 01:08:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:08:41 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:08:44 DTC Client socket (483) | Creating socket. Using TLS 1.2. | 2017-12-29 01:08:44 DTC Client socket (483) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:08:44 DTC Client socket (483) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:09:05 * DTC Client socket (483) | Initiating close of socket by core. | 2017-12-29 01:09:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:09:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:09:05 DTC Client socket (483) | Closed. | 2017-12-29 01:09:05 Bitfinex | Disconnected. | 2017-12-29 01:09:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:09:05 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:09:08 DTC Client socket (485) | Creating socket. Using TLS 1.2. | 2017-12-29 01:09:08 DTC Client socket (485) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:09:08 DTC Client socket (485) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:09:30 * DTC Client socket (485) | Initiating close of socket by core. | 2017-12-29 01:09:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:09:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:09:30 DTC Client socket (485) | Closed. | 2017-12-29 01:09:30 Bitfinex | Disconnected. | 2017-12-29 01:09:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:09:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:09:33 DTC Client socket (486) | Creating socket. Using TLS 1.2. | 2017-12-29 01:09:33 DTC Client socket (486) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:09:33 DTC Client socket (486) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:09:54 * DTC Client socket (486) | Initiating close of socket by core. | 2017-12-29 01:09:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:09:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:09:54 DTC Client socket (486) | Closed. | 2017-12-29 01:09:54 Bitfinex | Disconnected. | 2017-12-29 01:09:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:09:54 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:09:57 DTC Client socket (487) | Creating socket. Using TLS 1.2. | 2017-12-29 01:09:57 DTC Client socket (487) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:09:57 DTC Client socket (487) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:10:18 * DTC Client socket (487) | Initiating close of socket by core. | 2017-12-29 01:10:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:10:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:10:18 DTC Client socket (487) | Closed. | 2017-12-29 01:10:18 Bitfinex | Disconnected. | 2017-12-29 01:10:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:10:18 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:10:21 DTC Client socket (489) | Creating socket. Using TLS 1.2. | 2017-12-29 01:10:21 DTC Client socket (489) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:10:21 DTC Client socket (489) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:10:42 * DTC Client socket (489) | Initiating close of socket by core. | 2017-12-29 01:10:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:10:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:10:42 DTC Client socket (489) | Closed. | 2017-12-29 01:10:42 Bitfinex | Disconnected. | 2017-12-29 01:10:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:10:42 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:10:45 DTC Client socket (490) | Creating socket. Using TLS 1.2. | 2017-12-29 01:10:45 DTC Client socket (490) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:10:45 DTC Client socket (490) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:11:06 * DTC Client socket (490) | Initiating close of socket by core. | 2017-12-29 01:11:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:11:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:11:06 DTC Client socket (490) | Closed. | 2017-12-29 01:11:06 Bitfinex | Disconnected. | 2017-12-29 01:11:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:11:06 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:11:10 DTC Client socket (492) | Creating socket. Using TLS 1.2. | 2017-12-29 01:11:10 DTC Client socket (492) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:11:10 DTC Client socket (492) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:11:30 * DTC Client socket (492) | Initiating close of socket by core. | 2017-12-29 01:11:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:11:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:11:30 DTC Client socket (492) | Closed. | 2017-12-29 01:11:30 Bitfinex | Disconnected. | 2017-12-29 01:11:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:11:30 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:11:33 DTC Client socket (493) | Creating socket. Using TLS 1.2. | 2017-12-29 01:11:33 DTC Client socket (493) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:11:33 DTC Client socket (493) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:11:55 * DTC Client socket (493) | Initiating close of socket by core. | 2017-12-29 01:11:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:11:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:11:55 DTC Client socket (493) | Closed. | 2017-12-29 01:11:55 Bitfinex | Disconnected. | 2017-12-29 01:11:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:11:55 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:11:58 DTC Client socket (494) | Creating socket. Using TLS 1.2. | 2017-12-29 01:11:58 DTC Client socket (494) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:11:58 DTC Client socket (494) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:12:18 * DTC Client socket (494) | Initiating close of socket by core. | 2017-12-29 01:12:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:12:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:12:18 DTC Client socket (494) | Closed. | 2017-12-29 01:12:18 Bitfinex | Disconnected. | 2017-12-29 01:12:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:12:18 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:12:22 DTC Client socket (496) | Creating socket. Using TLS 1.2. | 2017-12-29 01:12:22 DTC Client socket (496) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:12:22 DTC Client socket (496) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:12:43 * DTC Client socket (496) | Initiating close of socket by core. | 2017-12-29 01:12:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:12:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:12:43 DTC Client socket (496) | Closed. | 2017-12-29 01:12:43 Bitfinex | Disconnected. | 2017-12-29 01:12:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:12:43 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:12:46 DTC Client socket (497) | Creating socket. Using TLS 1.2. | 2017-12-29 01:12:46 DTC Client socket (497) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:12:46 DTC Client socket (497) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:13:07 * DTC Client socket (497) | Initiating close of socket by core. | 2017-12-29 01:13:07 DTC Client socket (497) | Closed. | 2017-12-29 01:13:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:13:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:13:07 Bitfinex | Disconnected. | 2017-12-29 01:13:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:13:07 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:13:10 DTC Client socket (499) | Creating socket. Using TLS 1.2. | 2017-12-29 01:13:10 DTC Client socket (499) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:13:10 DTC Client socket (499) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:13:31 * DTC Client socket (499) | Initiating close of socket by core. | 2017-12-29 01:13:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:13:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:13:31 DTC Client socket (499) | Closed. | 2017-12-29 01:13:31 Bitfinex | Disconnected. | 2017-12-29 01:13:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:13:31 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:13:34 DTC Client socket (500) | Creating socket. Using TLS 1.2. | 2017-12-29 01:13:34 DTC Client socket (500) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:13:34 DTC Client socket (500) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:13:55 * DTC Client socket (500) | Initiating close of socket by core. | 2017-12-29 01:13:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:13:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:13:55 DTC Client socket (500) | Closed. | 2017-12-29 01:13:55 Bitfinex | Disconnected. | 2017-12-29 01:13:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:13:55 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:13:58 DTC Client socket (501) | Creating socket. Using TLS 1.2. | 2017-12-29 01:13:58 DTC Client socket (501) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:13:58 DTC Client socket (501) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:14:19 * DTC Client socket (501) | Initiating close of socket by core. | 2017-12-29 01:14:19 DTC Client socket (501) | Closed. | 2017-12-29 01:14:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:14:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:14:19 Bitfinex | Disconnected. | 2017-12-29 01:14:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:14:19 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:14:22 DTC Client socket (503) | Creating socket. Using TLS 1.2. | 2017-12-29 01:14:22 DTC Client socket (503) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:14:22 DTC Client socket (503) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:14:43 * DTC Client socket (503) | Initiating close of socket by core. | 2017-12-29 01:14:43 DTC Client socket (503) | Closed. | 2017-12-29 01:14:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:14:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:14:43 Bitfinex | Disconnected. | 2017-12-29 01:14:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:14:43 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:14:46 DTC Client socket (504) | Creating socket. Using TLS 1.2. | 2017-12-29 01:14:46 DTC Client socket (504) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:14:46 DTC Client socket (504) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:15:07 * DTC Client socket (504) | Initiating close of socket by core. | 2017-12-29 01:15:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:15:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:15:07 DTC Client socket (504) | Closed. | 2017-12-29 01:15:07 Bitfinex | Disconnected. | 2017-12-29 01:15:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:15:07 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:17:07 DTC Client socket (508) | Creating socket. Using TLS 1.2. | 2017-12-29 01:17:07 DTC Client socket (508) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:17:07 DTC Client socket (508) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:17:28 * DTC Client socket (508) | Initiating close of socket by core. | 2017-12-29 01:17:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:17:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:17:28 DTC Client socket (508) | Closed. | 2017-12-29 01:17:28 Bitfinex | Disconnected. | 2017-12-29 01:17:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:17:28 The message log has been sent to support. | 2017-12-29 01:18:50 * HTTPS connection to www.sierrachart.com:443 (510) | Creating socket. Using TLS 1.2. | 2017-12-29 01:18:50 HTTPS connection to www.sierrachart.com:443 (510) | Connecting to IP: 204.15.192.108. | 2017-12-29 01:18:50 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2017-12-29 01:18:52 HTTPS connection to www.sierrachart.com:443 (510) | Socket gracefully closed by remote side. | 2017-12-29 01:18:56 HTTPS connection to www.sierrachart.com:443 (510) | Received socket Close event. | 2017-12-29 01:18:56 HTTPS connection to www.sierrachart.com:443 (510) | Initiating close of socket by core. | 2017-12-29 01:18:56 HTTPS connection to www.sierrachart.com:443 (510) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-12-29 01:18:56 HTTPS connection to www.sierrachart.com:443 (510) | Closed. | 2017-12-29 01:18:56 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:19:29 DTC Client socket (512) | Creating socket. Using TLS 1.2. | 2017-12-29 01:19:29 DTC Client socket (512) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:19:29 DTC Client socket (512) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-12-29 01:19:49 * DTC Client socket (512) | Initiating close of socket by core. | 2017-12-29 01:19:49 DTC Client socket (512) | Closed. | 2017-12-29 01:19:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-29 01:19:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:19:49 Bitfinex | Disconnected. | 2017-12-29 01:19:49 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-29 01:19:49 Bitfinex | Connecting to the server dtc.bitsouk.com. Port 5571 | 2017-12-29 01:21:50 DTC Client socket (515) | Creating socket. Using TLS 1.2. | 2017-12-29 01:21:50 DTC Client socket (515) | Connecting to IP: 52.48.47.23. | 2017-12-29 01:21:50 |
[2017-12-29 22:18:20] |
For Bitfinex, only market data is supported at this time and to use that, follow the instructions here: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-29 22:59:25
