Date/Time: Mon, 29 Apr 2024 15:55:49 +0000
Detect modification of a member of the s_UseTool structure
View Count: 1023
[2017-12-28 18:55:30] |
@sstfrederik - Posts: 403 |
Hi, For a client project I am adding a s_UseTool DrawingType "DRAWING_LINE" to a chart with ACSIL. This drawing can be modified by a user. I would like to detect changes made to some of the line properties by a user. I detect all the things I need except one. What I cannot find in the s_UseTool member description. I would like to know if there is a member that sets the right Ext checkbox value. If this is not available can this be added? edit: I tried using "ExtendRight" but it does not work on DRAWING_LINE. Thanks in advance. Frederik Date Time Of Last Edit: 2017-12-28 19:01:52
LinePorperties.PNG / V - Attached On 2017-12-28 18:51:26 UTC - Size: 7.26 KB - 362 views |
[2018-01-07 20:25:53] |
Can ExtendRight be added as a UseTool member for the Drawing Type DRAWING_LINE ?
[2018-01-08 03:07:04] |
This is still pending.
[2018-01-08 10:22:35] |
We have now had a chance to look into this. When extending a Line Drawing to the right, it is transformed into a Ray drawing so you just need to check this member to see if it is a Ray: https://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html#DrawingType Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-08 10:24:26
