Date/Time: Sat, 27 Apr 2024 23:04:04 +0000
how to set Data/services setting automatically login with last time working broker?
View Count: 1082
[2017-12-28 01:04:13] |
User567294 - Posts: 47 |
I want to let Sierra Chart start with last time working data/services setting without manually choose. Can I do that ? thanks Rex |
[2017-12-28 02:10:44] |
This will automatically be the case. Do you mean that Global Settings >> Data/Trade Service Settings >> Service is changing every time you start Sierra Chart?
[2017-12-28 02:13:18] |
yes, every time I start it, it always changed to other one, not the one last working broker.
[2017-12-28 02:45:47] |
When you select Help >> About from within Sierra Chart, does the account name match the account name we see that you are using to start this support request with?
[2017-12-28 02:48:52] |
yes
[2017-12-28 19:34:47] |
Therefore, it seems as though the only explanation is that the main configuration file is read-only. Refer to: Error Messages When Opening Files But just to be sure, after restarting Sierra Chart provide a copy of the Message Log following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-28 19:35:57
[2017-12-29 15:58:29] |
ok, will try that. thanks |
