Date/Time: Thu, 02 May 2024 09:22:39 +0000
BitMex second account
View Count: 1632
[2017-12-27 21:01:31] |
N!co - Posts: 140 |
Hi, Would it be possible to connect a second instance of Sierra chart to a second BitMex account ? i know BitMex will generate me a second and different API code but in BitMex i also need to specify my user name , and obviously this is the same SC user name for both BitMex accounts in the Sierra chart data connection setting i see nothing to seperate the 2 account thank you |
[2017-12-28 01:01:43] |
Yes this is no problem. You can use the same Sierra Chart account. You can choose between the accounts through the Trade Window: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-28 06:26:49] |
Here is the relevant documentation for this: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#UsingMultipleBitMEXAccounts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-28 18:58:24] |
N!co - Posts: 140 |
That is not working for me i generated a second API key on the second BitMex account BUT ona account #1 and #2 i need to put in my SC user name , so this is the same on both account now when i star a second SC it connect to the same account , and i have now option as to select a second account |
[2017-12-28 19:05:36] |
Based on what you are saying it does not sound like there is a problem. Just use the account you want to use by selecting it through the Trade Window: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-28 19:22:11
