Date/Time: Sat, 27 Apr 2024 20:40:00 +0000
DRAWSTYLE_IGNORE and display name and value in region data line
View Count: 826
[2017-12-23 05:45:30] |
User43311 - Posts: 3 |
Hello, when I use DRAWSTYLE_IGNORE, sierra don't display name and value in region data line (MinAsk - SG1). Why? Thanks Petr Date Time Of Last Edit: 2017-12-23 05:47:46
2017-12-22_2346.png / V - Attached On 2017-12-23 05:47:09 UTC - Size: 54.72 KB - 293 views |
[2017-12-27 18:08:48] |
This is not supported when the draw style is set to Ignore.
