Date/Time: Mon, 29 Apr 2024 08:38:23 +0000
zigzag indicator causes the price chart to flatten on Ratio Charts
View Count: 748
[2017-12-22 13:08:29] |
User511630 - Posts: 3 |
Hi SC Team, I could not find a specific answer to this problem on your boards. I have created ratio charts, for eg gbyjpy using (gbpusd / jpyusd) cme futures, using your recommend steps in the article [How to Create High Accuracy Spread or Ratio Charts]. most indicators work okay. however, adding the zigzag indicator causes the price chart to flatten. is there a solution to this problem? or are indicators based on prices of the 1st instrument (gbpusd futures) & not the computed price of the ratio chart? Thank you |
[2017-12-22 19:34:57] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
