Date/Time: Fri, 03 May 2024 08:38:01 +0000
simple chart trading questions
View Count: 735
[2017-12-22 12:05:41] |
ycomp - Posts: 274 |
somehow I enabled a mode on the chart that displays the volume of orders with red and green bars on the right side. What is the called and where can I read more about this? Also, how do I change the display units in the chart trading pane for P/L.. what does P mean? points? |
[2017-12-22 19:32:42] |
1. This is called the Chart DOM. Refer to: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns 2. Refer to this setting here: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) (ProfitLossFormat) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
