Date/Time: Tue, 30 Apr 2024 14:26:22 +0000
live stream
View Count: 857
[2017-12-19 19:55:58] |
User850017 - Posts: 41 |
I have this datafeed and live stream from SC. But GBLX ES, NQ is delayed. Why?
[2017-12-19 21:43:42] |
Do you use Interactive Brokers for your futures trading?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-19 21:43:48
[2017-12-20 07:56:00] |
YES.
[2017-12-20 17:17:00] |
Therefore, you need to follow the instructions here to accommodate the stupid rules from the CME: Sierra Chart Exchange Data Feed: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-20 17:17:40
