Date/Time: Sat, 27 Apr 2024 15:43:09 +0000
Volume At Price Threshold Alert V2: price position of positive diagonal ratios
View Count: 1442
[2017-12-18 23:25:05] |
Jezz - Posts: 33 |
Hi As shown in figure, when using Volume At Price Threshold Alert V2 to mark diagonal ratios, there is a strange behavior: Negative ratios are placed at the right price value, but negative ones are drawn one tick below. https://i.imgur.com/GqdV5uv.png Thanks |
[2017-12-19 02:14:02] |
We will only accept a chart image posted by this method: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image We do not accept external links. What you see is by design. You can modify the study to meet your own requirements. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-19 02:14:18
[2017-12-19 09:05:24] |
Jezz - Posts: 33 |
Thanks for your quick response Sorry, I cannot compose and annotate screen portions by using Sierra Chart Image Upload Service. > You can modify the study to meet your own requirements I'll learn and try my best Thanks again |
[2017-12-19 09:57:51] |
Jezz - Posts: 33 |
Hey I did it. It was not that difficult Thanks again |
[2017-12-19 19:22:58] |
Sorry, I cannot compose and annotate screen portions by using Sierra Chart Image Upload Service. https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image The problem with external image services, is that the image may no longer be available, and due to security software that we run, often these images just do not even display for us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-19 19:23:10
[2017-12-19 20:26:09] |
Jezz - Posts: 33 |
OK, I'll try it next time Thanks |
