Date/Time: Thu, 02 May 2024 16:50:10 +0000
CTS mobile usage
View Count: 974
[2017-12-18 21:54:28] |
User134590 - Posts: 12 |
Hello, I am currently using the CTS-Dorman-DTC model with Sierra Charts - Excellent and stable In the description for the lower cost model - it states that CTS front ends are available to use (25 a month and .50 per side) I have installed the CTS mobile app on a tablet but the only information displayed is account balance - no incoming quotes, positions, etc.... I am not connected on the desktop to CTS (no concurrent use) - I believe that I have to also subscribe to the CTS datafeed (through T4 login) in order to use mobile right? The mobile app doesn't have any connection with Sierra Chart's Exchange Data Feed - it's only powered by native CTS feed correct? Please advise Tnanks |
[2017-12-18 22:57:25] |
I believe that I have to also subscribe to the CTS datafeed (through T4 login) in order to use mobile right? The mobile app doesn't have any connection with Sierra Chart's Exchange Data Feed - it's only powered by native CTS feed correct? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
