Date/Time: Mon, 29 Apr 2024 13:28:07 +0000
Trading DOM - Text in Volume Bars
View Count: 1049
[2017-12-18 18:22:18] |
Bitboy - Posts: 13 |
Hello, Just added Volume by Price study to the Trading DOM, the POC and VAL lines are over the Text in the Volume Bars.. so i cant read the Volume.. where can i change it? kind regards! http://www.sierrachart.com/image.php?Image=1513621117370.png |
[2017-12-18 18:47:50] |
Is that the only study you have added to the trading DOM? We do not observe this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-18 20:52:53] |
Yes thats the only one!
[2017-12-18 22:06:56] |
Perhaps you are using transparency for that study. Do not use that because it is inefficient and creates problems like this. Otherwise, we do not have an answer for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-18 23:22:40
[2017-12-18 23:22:02] |
If the transparency is not the issue, we will need to get this Chartbook and test it since we cannot think of any other reason. Follow the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-18 23:22:10
[2017-12-19 19:12:03] |
Thank you for your Help.. I created a new Chartbook... and in this chartbook its correct.. , i created a new dom in the old chartbooks and its also correct there.. i dont know what the problem was, but now its ok! |
