Date/Time: Fri, 03 May 2024 14:15:08 +0000
ACSIL : get chart number time frame ?
View Count: 1042
[2017-12-18 14:58:36] |
wwwingman - Posts: 185 |
Hi I would like to know the time frame of an open chart. I alraedy use sc.AreTimeSpecificBars()and sc.SecondsPerBar() for the current chart, but I need that for any open chart. Is there a function/simple way to already to that ? Is it possible to enhance current Sierra with such functions ? Thx. -- W. |
[2017-12-18 18:26:47] |
We will be improving upon this soon. Hopefully, not later than a month or two.
