Date/Time: Fri, 03 May 2024 10:38:29 +0000
CTS T4 and BTC
View Count: 653
[2017-12-18 14:44:41] |
ecerejo - Posts: 16 |
Hello, Even though I can find BTC under symbol settings I can't find it under foreign exchange! Is anyone aware of this? |
[2017-12-18 18:36:24] |
We did not have the exchange set correctly for the symbol and it was not in the right category. This is now corrected. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings It is now listed under CME Equity Futures. The symbol is: BTC.20170100.CME_Eq Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
