Date/Time: Thu, 02 May 2024 07:07:12 +0000
Not enough price data showing when using 12 range chart for Dax futures
View Count: 763
[2017-12-18 10:46:55] |
User829216 - Posts: 15 |
When I use the 12 range chart I can only 'scrunch' up about 5 days worth of chart data to show up on my screen. Scrolling left allows me to see several weeks but I lose current weeks data as I scroll the screen to the left to see historical price levels. When I use 55 range or 30 min chart I can 'scrunch' up several weeks with of data to show up on my screen. please see the attachments as these may help. thx and best regards LB |
Dax 55R chart.png / V - Attached On 2017-12-18 10:46:16 UTC - Size: 108.94 KB - 281 views 12Range Dax.png / V - Attached On 2017-12-18 10:46:34 UTC - Size: 123.91 KB - 282 views |
[2017-12-18 18:14:09] |
You just need to increase the range of the chart bars. There is no other solution.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-18 18:14:22
[2017-12-18 18:49:03] |
thx for the response. ah ok so can only be done by going to a wider range. Shame Ninja allows this maybe worth it in the future? does this only apply to range bars or is it the same for lower time frames like 5min 3min? also tick bars? many thx in advance Lb |
[2017-12-18 19:31:08] |
We do not see this ever coming in the future. It inherently makes no sense. It applies no matter what the timeframe of the chart bar is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-18 19:31:14
