Date/Time: Mon, 29 Apr 2024 16:54:05 +0000
POint and figure
View Count: 1165
[2017-12-17 23:16:53] |
James Walker - Posts: 2 |
can I do point and figure one-step-back with Sierra?
[2017-12-18 18:28:21] |
We do not know what this means. What do you mean by one step back?
[2017-12-19 23:27:58] |
It is discussed in this thread, which I find inconclusive. Your comment would be appreciated. 1 Box Reversal Point & Figure Chart With 'One-Step-Back' |
[2017-12-21 04:40:11] |
What you are looking for is not supported. In general, it is a significant amount of work to support X's and O's in the same column. We will have to look at this later on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
