Date/Time: Sun, 05 May 2024 20:00:12 +0000
Study Summary settings - issue
View Count: 816
[2017-12-16 00:10:36] |
sampater - Posts: 243 |
Issue: 1) disable the Include in Summary option in the Subgraphs tab. 2) Check "Save these settings as the default" and OK. 3) Remove and add again the same study. 4) Option Include in Summary is still enable. |
[2017-12-16 04:02:27] |
Will make sure these new settings are saved as defaults.
