Date/Time: Sun, 28 Apr 2024 19:10:33 +0000
[Programming Help] - TRADING SYSTEM
View Count: 731
[2017-12-15 20:33:39] |
User82615 - Posts: 106 |
HELLO I HAVE BEEN BACK TESTING MY TRADING SYSTEMS PROGRAMMED IN ACSIL FOR A LONG TIME WITH SIERRA CHARTS AND EVERYTHING WORKED GREAT , UNTIL TODAY , THE BACKTESTING THAT APPEARS IS NOT CORRECT FOR EXAMPLE I PROGRAM A BUY ORDER WHEN LAST OF A BAR IS GREATER THAN THE OPEN OF A BAR AND IT DOESN'T WORK GOOD IT BUYS ALSO WHEN THE LAST OF THE BAR IS LOWER THAT THE OPEN OF THE BAR ,AND LIKE THIS ANY OTHER RESTRICTIONS THAT I PROGRAM FOR THE ORDER THEY DON'T WORK, THEY DON'T APPER IN BACKTESTING. I DIDN'T CHANGE ANYTHING , DO YOU THINK IT COULD BE A PROBLEM IN MY COMPUTER. IF NOT WHAT COULD I DO? THANK YOU VERY MUCH FOR YOUR HELP |
[2017-12-15 21:32:50] |
I ALREADY SOLVED IT THANK YOU
