Date/Time: Sat, 04 May 2024 08:32:02 +0000
Charts Hidden | Alert Manager Go To Chart button not possible
View Count: 761
[2017-12-15 12:21:39] |
User10875 - Posts: 42 |
Hello, I have a large list of stocks setup with an alert. The charts are hidden to save memory. However if an alert is triggered the related hidden chart cannot be opened directly via the " Go to Chart" button in the alert manager. Having a long list of intraday charts in takes some crucial seconds to find the chart via the CW window. Is it possible to make the "Go to chart" button available for hidden charts as well? Kind regards |
[2017-12-15 18:52:28] |
Yes, we will make that work.
