Date/Time: Thu, 02 May 2024 07:49:48 +0000
server side orders
View Count: 826
[2017-12-15 08:08:20] |
User825473 - Posts: 24 |
Hello, With IB (TWS) do you reccomend to ENABLE Server side OCO and Bracket orders, or not? |
[2017-12-15 17:38:36] |
Overall it would be safest to use Interactive Brokers server-side orders but sometimes we do hear about problems with those. To enable them, refer to: Global Trade Settings Windows: Use Server Side OCO Orders (if supported) (Global Settings >> General Trade Settings >> General) Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
