Date/Time: Sun, 28 Apr 2024 12:49:52 +0000
Changing DOM colors for sell stop orders
View Count: 1001
[2017-12-14 18:24:45] |
User223270 - Posts: 3 |
Dear SierraChart Tech Support, I can't read the numbers with the default shade of red for Sell Stop Orders. Which is the name of the command I should look for on the left side of the column as shown in the attached screenshot in order to change that dark red color on the right? Thank you! Kind regards Christian B. |
DOM Sell Stop colors -- 2017-12-14_17-26-34.jpg / V - Attached On 2017-12-14 18:23:46 UTC - Size: 203.82 KB - 305 views |
[2017-12-14 22:11:08] |
This is the color setting: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Order Line Text Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-15 08:23:03] |
Thank you but I knew that link; I can't figure out which is the name of the command I am using. There are no actual examples in your online manual, just names. And there is no filter under 'Colors and Widths' in order to understand which section the trader is actually changing. There is no previews of what the user is tweaking.
[2017-12-15 09:38:23] |
We linked to: Trade DOM Order Line Text Color This is the color setting you need to change. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-16 20:34:25] |
Perfect! Sorry -- I did not realize that was the proper link and feature to be managed directly.
