Date/Time: Sun, 28 Apr 2024 16:12:23 +0000
Problem with LMAX DTC connection in latest version 1669
View Count: 623
[2017-12-14 17:34:25] |
AlexPereira - Posts: 197 |
Hi, Updated from version 1665 ( which is/was working) to 1669, and now I cannot login to LMAX broker. Message log outputs this error: LMAX Live Trading - DTC (Data) | Logon error received from server: Data service (LMAXLiveTrading.DTC) is disabled/unsupported. Update Sierra Chart to the current version. | 2017-12-14 17:31:25 Is it any error on my part ? Thanks Date Time Of Last Edit: 2017-12-14 17:35:05
[2017-12-14 17:40:54] |
Try now. The connection should work.
[2017-12-14 17:43:14] |
Confirm that its working now, Thanks for the quick support ! Date Time Of Last Edit: 2017-12-14 17:43:39
