Date/Time: Tue, 30 Apr 2024 18:58:38 +0000
quotes
View Count: 734
[2017-12-13 17:03:05] |
User28682 - Posts: 233 |
What is wrong with SC quotes in the last week??? They go through short periods where they stop updating, then start again. This is annoying and hard to trade off of. I have other platforms and can see this happening with SC.
[2017-12-13 18:57:35] |
We see no evidence of a problem and have no other reports of this. Go to a chart and select File >> Open Time and Sales Window. When you see a time when there is no updating and then you see new trades occur, are the timestamps delayed? If so, by how much? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-13 19:00:06] |
Refer to the post above. This also could be due to a high CPU usage issue at times. In that case, refer to help topic 4.3 for more information on how to determine this: http://www.sierrachart.com/index.php?page=doc/helpdetails4.html#h4.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-13 19:00:54
