Date/Time: Sat, 27 Apr 2024 15:09:57 +0000
Build an automated trading system with spreadsheet using Volume profile and market depth d
View Count: 978
[2017-12-13 16:00:44] |
User252419 - Posts: 235 |
I want to build an automated trading system with spreadsheet using volume profile and market depth. I'm absolutely new with spreadsheet and I don't find any clue on how to start. Could you give me some links/material to read in order to start? Thank you |
[2017-12-13 20:57:48] |
We think it is best that you would use ACSIL: Advanced Custom Study Interface and Language (ACSIL) However, if you want to use Spreadsheets, you can use this Input for the volume at price data: Spreadsheet Study Inputs: Output Volume at Price Data And you can use this study for market depth data: Depth of Market Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-13 20:59:51
[2017-12-13 20:59:06] |
The prior post has been updated. It was incomplete at the time we posted it.
