Date/Time: Sun, 28 Apr 2024 10:09:19 +0000
charting
View Count: 802
[2017-12-12 13:25:48] |
User841161 - Posts: 196 |
I change between data sources cts t4 FIX and sc data all sources, but some of my charts don't work when changing from one to the other because of the change of symbols each uses. Is there an easy and efficient way to get charts up and going when changing between the two data sources.
[2017-12-12 17:36:27] |
We do not recommend doing this. The symbols and data formats are different. We are not going to provide support for the complications associated with that. Instead what you need to do is to use two separate copies of Sierra Chart. One for each service. Follow the instructions here: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
