Date/Time: Sun, 28 Apr 2024 21:51:58 +0000
Renko Open and Renko Close often = 0
View Count: 1075
[2017-12-12 12:20:40] |
gomifromparis - Posts: 244 |
Hi, It seems that on some charts, Renko Open and Renko Close are often equal to 0. Here's a sample on FDAX. I plot SMA(Renko Open,1) and SMA(Renko Close,1) Sometimes there is a value, sometimes it's 0 and SMA gets off the chart. |
renkoopenclose.png / V - Attached On 2017-12-12 12:20:24 UTC - Size: 52.94 KB - 246 views |
[2017-12-12 18:06:13] |
Is the Renko New Bar Mode you are using use New Bar When Open Crossed? This would only be a problem with the last bar in the chart. And we will find a solution to that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 18:20:57] |
hm yes , looks like it, it seems I was on default settings on my chart and I didn't select the good illogical setting (the 3rd one). Will report if it happens on it
[2017-12-12 18:33:07] |
It can only happen with New Bar When Open Crossed and we will solve that.
