Date/Time: Sun, 28 Apr 2024 19:37:50 +0000
Issue loading continuous futures contract
View Count: 1002
[2017-12-11 14:03:07] |
User791167 - Posts: 22 |
Whenever I load a chart with a continuous contract, I get this series of messages for the chart: @EU# [CV] 240 Min #9 | Reloading chart. | 2017-12-11 07:17:44 @EU# [CV] 240 Min #9 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2017-12-11 07:17:44 @EU# [CV] 240 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2017-12-11 07:17:44 I can attach pics if need be... My Chart settings are as follows: Main Settings: Days to load: 3000 Symbol: @EU# Chart Data Type: Intraday Chart Only Intraday Chart Bar Period: Bar Period Type: Days-Mins-Secs Per Bar Setting: 0-240-0 Gap Fill - None Start Time: 17:00:00 End Time: 16:00:00 New Bar At Session Start: Checked - Do Not Load Weekend Data Advanced Settings: Display Main Price Graph Values in Values Windows - Checked Draw Highlight Drawings Underneath Main Graph and Studies - Checked Highlight Timescale Dates, Months and Years - Checked Adjust Tool Values to Tick Size - Checked Continuous Contract: Continuous Futures Contract - Volume Based Rollover Split Data Records - Checked Apply Intraday Session Times To Intraday Chart - Checked Include Sat-Sun Bars For Daily Charts - Checked |
[2017-12-11 18:37:12] |
@EU# is already a continuous futures contracts symbol. Chart >> Chart Settings >>Continuous Contract needs to be set to None. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 03:30:59] |
Thanks. By changing this to None, do you know if it will change the way any of my data is displayed on my charts? |
[2017-12-12 03:48:11] |
No. It really makes no difference other than removing the error message.
[2017-12-12 13:36:09] |
ok thank you
